Old 06-22-2012, 06:34 AM   #1
tony005
Drives: Toyota Yaris T3 Spirit
Instrument Panel Fuse box location?: Yaris T3 Spirit
My Instrument panel/ dashboard is not lighting up.
I believe its a burned fuse.
Where will this fuse be located?
Thanking you in advance
tony005 is offline   Reply With Quote
Old 06-22-2012, 06:49 AM   #2
Is your T3 a first or second generation Yaris?
If it is a 2nd gen (06-11), then the fuse box is located under the bottom of the dashboard on the driver's side of the car. You would check the PANEL 1, PANEL 2 and MET fuses.
If it is a 1st gen (99-05), then the fuse box is located behind the small storage cup on the lower dash on the driver's side. On the 1st gen the TAIL fuse supplies illumination power to the panel.
Old 06-22-2012, 09:32 AM   #3
tony005
Thnx for the reply,
It is a 2nd gen.
but did not find it where you suggested.
I located a fuse box behind the glove compartment, but it is not the one that has the fuse that im looking for. any other place?
Old 06-22-2012, 10:10 AM   #4
Originally Posted by tony005 View Post
Thnx for the reply,
It is a 2nd gen.
Look under the bottom of that fuse panel.
Check out this yaris panel!! marcus General Yaris / Vitz Discussion 11 10-25-2006 03:28 PM
Centre Panel Yaris Sedan dngz Cosmetic Modifications (Exterior/Interior) 19 09-05-2006 05:00 PM
