Old 08-06-2009, 09:18 AM   #1
jonismyname
Drives: 08 liftback 5spd
11.52 gallons... how much was in the tank?
running a bit low the other day. put in 11.52 gallons of fuel. any idea how much further i had to go before stutter and fail? how much have you put in your tank?
don't tell me it's bad for my fuel pump. i know that. it's common knowledge. thanks though.
ever ran out? what'd it take to fill up again?
jonismyname is offline   Reply With Quote
Old 08-06-2009, 09:38 AM   #2
I think the tank capacity is about 11 and a bitt gallons? talk about running on fumes!
Old 08-06-2009, 09:40 AM   #3
11.1 is what the manual says for capacity. Either the gas pump was miscalibrated, or you had 1/2 gallon in the filler pipe.
Old 08-06-2009, 09:54 AM   #4
jonismyname
i've gone over 11.1 before, both by scan-gauge and actual gas that went in...
Old 08-06-2009, 09:55 AM   #5
jonismyname
i assume it was the filler neck (i don't top off) but was wondering if anyone's gone further?
Old 08-06-2009, 10:21 AM   #6
Lafiro
Drives: 06 Yaris Sedan
Yeah I know the other day I pushed my car to the limit without gas.
Ended up putting a total of 11.5 something gallons in.
Don't know how that was possible, or if the gas station is making money off the pump.
Old 08-06-2009, 10:36 AM   #7
If you do the math, the filler pipe adds about 0.3 to 0.5 gallons to the capacity.
Old 08-06-2009, 12:35 PM   #8
cdavidhess
cdavidhess's Avatar
Drives: 2008 White Yaris Sedan 5 speed
I did 11.5 gallons on a tank one time. It was also my record range on a tank - 502.4 miles.
cdavidhess is offline   Reply With Quote
Old 08-06-2009, 12:52 PM   #9
2009Toyotoad
Drives: 2009 Yaris 3dr
jonismyname,
You do realize that running the fuel to that low is not good for the fuel pump. Since the in tank fuel pump normally to surrounded by fuel it uses the fuel to transfer away the heat. The pump isn't as efficient when to transfers that heat to the air in the tank. Give your fuel pump a longer life re-fuel at the half empty level.
2009Toyotoad is offline   Reply With Quote
Old 08-06-2009, 01:01 PM   #10
MadMax
MadMax's Avatar
I put in 11.6 gals once, but that was when I used to fill it up to the point of slooshing out the top. Still, I've gotten 11.4 gals in more recently when stopping after the second cuttoff...
Cheers! M2
Old 08-06-2009, 02:37 PM   #11
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Hey, did you know that running the tank dry may be hard on your fuel pump?
Old 08-06-2009, 03:48 PM   #12
jonismyname
thank you
Old 08-06-2009, 03:59 PM   #13
Yaris Hilton
Smile
Anytime.
Old 08-06-2009, 04:13 PM   #14
jonismyname
http://action.publicbroadcasting.net...st/546410.page
folks disregarding original post can post above, they've already got the ball rolling...
how much heat do these disperse into the fuel anyways? compared to the heat that's carried up and out of the pump with the fuel?
maybe someone needs to create a cooling system for the in-line out of tank gyrator type pumps i sell? carter and holley got some news coming to them...
on topic- it appears 11.5 is the ultimate cutoff... i wish mother toyota could've incorporated a slightly more accurate fuel gauge... now i have a better idea what to track with the scangauge...
Old 08-27-2009, 04:34 PM   #15
Kal-El
Kal-El's Avatar
Originally Posted by 2009Toyotoad View Post
jonismyname,
You do realize that running the fuel to that low is not good for the fuel pump. ...
Old 03-29-2013, 08:34 PM   #16
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Welcome to the forum, blown...
Just a heads up. That thread is over 3 years old so it's likely no one who posted there will answer. But your point is well taken, 40 mpg is far more realistic than 50.
Old 03-29-2013, 10:31 PM   #17
nookandcrannycar
Didn't you do a calculation at one point to determine what the absolute maximum capacity would be to the top of the neck and came up with 12.8 gallons? (I know, it's not recommended/safe/etc. to go past the click) The 12.8 seemed really accurate to me because I once ran out of gas pulling into a station to get gas, and filled up to where I could start to see the gas in the neck. The total was 12.777 gallons.
Old 03-29-2013, 10:33 PM   #18
Yes. This thread was from two years prior to me doing that though.
Oil catch tank question window_lee General Yaris / Vitz Discussion 1 07-14-2009 08:04 AM
Additives Yar Is Word Fuel Economy Forum 66 06-05-2009 09:55 AM
Last Fuel Bar andaconda Fuel Economy Forum 37 04-29-2009 02:35 PM
5.996L/100KM, My third tank KKevin Fuel Economy Forum 2 03-03-2009 05:37 PM
How many miles are you getting on a tank? TDL General Yaris / Vitz Discussion 1 11-29-2006 04:28 PM
