Old 02-02-2009, 12:33 AM   #1
Yar Is Word
Drives: Yaris 5 door liftback
Additives
Hello! Pardon me if this has been covered elsewhere in this forum.
Just passing my experience along.
After seeing this product displayed at a Toyota dealer's parts department,
I decided to try a Lucas fuel additive.
Having used the Lucas fuel additive in an ECHO for approximately a year and a half, there has been a 2-4 mpg increase, after the third tank. A friend is using it in his Mercury Marquis and gets 2 mpg more.
Also, the ECHO's automatic was shifting harder 15,000 miles after new transmission fluid. With the Lucas transmission additive it shifted smoother right away.
These products were purchased at Baxter Auto Parts and were cheaper than at the Toyota dealer. The gas additive is about $12 for 26 oz. which is good for about 8 tanks at 3-4 oz per fillup. It has more than paid for itself.
I'll be using them in the Yaris.
Here is the Lucas product link: http://www.lucasoil.com/products/
Is anyone else using fuel saving additives?
Old 02-02-2009, 02:52 AM   #2
GeneW
Drives: 2008 Yaris
Are you saying that you changed the fluid at 15,000 miles and the new Toyota WTS fluid did the job its supposed to do, shift harder? Are you saying that 15,000 miles after you changed the fluid that the car shifted harder?
I've used a substance called P-blaster fuel injector cleaner. I have a friend who uses it at four times its normal concentration. So far nothing has flown apart for him. Of course he also recommended that I use Rotella-T 15W-40 in my Yaris, which prompted a pretty nasty fight between us.
Ordinarily one should not need additives, but sometimes we get gunk in our gasoline. Doesn't hurt to use moderate amounts of fuel injector cleaner from reputable sellers. I'll probably get a bottle of Pblaster and use it per instructions. Ought to last me quite a few years.
I myself would stay far far away from Tranny additives in Toyota products. If Toyota engineers are like the ones at Sony (who I once worked for as a Depot Repair Tech) and Honda (which I owned in the past) than they are not big believers in "robust engineering". This means that they design stuff very close to the edge as far as tolerances and specs. You cannot afford to mess with stuff too much.
Best example I can recall was when I used an aftermarket distributor cap in my Honda CRX. The Echlin cap was a work of art. Made of good quality plastic and brass fittings, far superior to the Honda offering that used crummy plastic and aluminum fittings. The car ran like crap with with the Echlin cap, but once I put the original Honda part in the car ran just fine.
Another was when I worked for Sony. Their electronics is really tight assed stuff, which requires tight tolerances on some parts. Like it's hard to cross reference some driver transistors because the engineers used them to specifically match what was needed. An American engineer might not be as tight assed, but who can say?
I do use a Napa Gold air filter in my Yaris. The quality of the filter to me is much higher than Toyota OEM. I plan to change it more frequently than the Toyota spec filter for this reason.
Gene
Old 02-02-2009, 05:53 AM   #3
NJBob
NJBob's Avatar
Drives: 2008 Yaris Liftback
Question
I looked at gas additives yesterday @ $4-5 dollars a bottle. Not to start a flame war but wouldn't it be cheaper just to buy higher octane at the pump? Or are their other benefits to additives?
Old 02-02-2009, 08:34 AM   #4
SilverGlow
Drives: 2007 Yaris Hatchback
Originally Posted by Yaris T-Sport View Post
I use Nos Octane booster with every fill up of tank with 91 octane, it, stops detonation and makes my car run like a champ. I have also used STP octane booster with 2 bottles per one tank, the detonation still there even with two bottles of those in one tank, and my car runs like sh*t with the STP octane booster.
as for MPG I;m getting around 25MPG
So you buy a product to hide the engine's ping problem? Not very smart. Why not take it in to get fixed? Our Yarii should not be pinging on 87 octane regular. My 2007 Yari HB with 51,000 miles has never pinged.
As to Lucas UCL, I noticed a 7% increase in MPG when used in every tank. The savings in gas more then pays for this product, and it keeps the combustion chamber clean.
SilverGlow is offline   Reply With Quote
Old 02-02-2009, 08:39 AM   #5
1stToyota
1stToyota's Avatar
It'd be cheaper to use 87 octane. Unless you're modded higher octane isn't needed and more likely you'll just lose mpg, instead of seeing a gain. Overtreating probably isn't good for the oil or the fuel pump. I use one bottle of Chevron Concentrate Plus (treats up to 12 gals) before each 5k OCI.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-02-2009, 08:39 AM   #6
SilverGlow
The amount of additives in premium gas is not very much, in comparison to adding a bottle of cleaner. Also, our Yarii do not benefit from higher octane gas, and in fact I found that my Yaris gets worse milage on premium. It's just not tuned to take advantage of the higher octane. Using premium is like throwing $ out the window.
Old 02-02-2009, 08:43 AM   #7
1stToyota
1stToyota's Avatar
I get detonation with boost, it's the timing, but 91 oct + Nos Octane booster = no problem
Maybe a safer, richer tune would solve the pinging problem.
2008 Scion xD
Old 02-02-2009, 10:09 AM   #8
NJBob
NJBob's Avatar
Question
Hmmmmmm..I just read an article touting a real result of around +8mpg. Worth looking into. Who sell's it? Pep Boys, Autozone....?
Old 02-02-2009, 10:17 AM   #9
1stToyota
1stToyota's Avatar
You should find the Lucas at most major part stores. The only reason I don't use it is because it's too hard to mess with. Even their small 5.25oz bottle is over twice too strong (treats 25 gallons).
2008 Scion xD
Old 02-02-2009, 11:22 AM   #10
YarisSedan
Drives: 08 Yaris Sedan
just run top tier gas and you will never have to add additives your engine will always be clean
http://www.toptiergas.com/
Old 02-02-2009, 11:28 AM   #11
ChinoCharles
Drives: LB
I'm so anxious to see what my engine looks like. I've run nothing but Shell. Well, then again, hopefully I'll never know what the inside of my engine looks like because it will never require me to look inside!
Old 02-02-2009, 07:50 PM   #12
Yar Is Word
Gene
Gene,
Sorry I did not make that clear. It was 15,000 miles after the 60,000 mile service, that the transmission was shifting harder. The Lucas transmission addiive made it shift smoother. I put only a couple ounces in and repeated after about 7500 more miles.
Here is the dealer site for Lucas where you can find the dealer nearest you in the USA:
http://www.lucasoil.com/retailers/
International:
http://www.lucasoil.com/pages3-7/LucasInternational
Old 02-02-2009, 07:55 PM   #13
Yar Is Word
Thank you for the info. It's good to know who the good guys are.
I used 76 premium in the ECHO. It ran better, got 2mpg more, and was stronger. Plus it got 2-4 mpg more on top of that with the Lucas fuel additive.
Old 02-02-2009, 08:17 PM   #14
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
why dont you just put in ethenol injection....? or just add it to the tank.... its an octane booster and cheeper then "Nos" 8ane booster
ka0sx is offline   Reply With Quote
Old 02-05-2009, 12:26 AM   #15
keesue
Chillin' out by the Bay
keesue's Avatar
Yep...
Gettin' all the way down.
Meteorite '07 HB STILL completely stock; but....
checkin' out da other ones to see what's what.
keesue is offline   Reply With Quote
Old 02-05-2009, 02:42 AM   #16
aca72
aca72's Avatar
Drives: '07 Yaris S Sedan M5
Lucas UCL in a Yaris at BITOG...
Lucas UCL - Is it worth it?
Without
Tank 1: 35.4
Tank 2: 35.1
Tank 3: 34.8
Tank 4: 33.9
Tank 5: 34.7
Tank 6: 35.8
Tank 7: 34.7
Average: 34.9MPG, or 349 miles per tankful.
With Lucas UCL
Tank 1: 36.2
Tank 2: 36.2
Tank 3: 38.4
Tank 4: 36.8
Tank 5: 37.9
Tank 6: 38.7
Tank 7: 37.2
Average: 37.3, or 373 miles per tankful.
aca72 is offline   Reply With Quote
Old 02-05-2009, 09:40 AM   #17
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
I used to use dry gas in this cold weather area but since the introduction of E-10 it is not needed.
For a fuel system cleaner I have always used Chevron Techron and it seems to have a good result ....... I only use it about 1x for 10K miles just for safety.
I am going to look into the Lucas but I have found better gas yields better MPG .... I will compare the prices between the addative and the high test gas.
Old 02-05-2009, 12:08 PM   #18
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
What method do you use to distinguish a better gas over a not so good gas?
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Will Sam's Club 85 fuel harm my engine? hans_fh General Yaris / Vitz Discussion 14 06-18-2007 02:40 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
