#19 | |
#20 |
![]() Drives: Yaris 1.0L Join Date: Mar 2011
#21 |
Here is the cluster and the clock on the right side
#22 |
That is the one that I have. I just disassembled mine and hooked it up on my test bench to experiment with it. The clock and odometer are a separate assembly from the rest of the instrument cluster. Does anything at all display on the clock area of yours?
#23 |
No nothing.Did you find something that can be replaced,or behind that LCD is a small electronic board.Maybe there is a malfunction,somethin broken or burned?
#24 |
The small LCD (which is actually a vacuum fluorescent display) for the clock and odometer is a separate assembly, so that could be replaced as it may be the bad part. There are three separate circuit boards - The large main on, the one that the speedometer display is mounted to, and the "Core" board, which snaps to the back of the large board. The Core board contains the primary processor for the cluster and it has the EEPROM where the odometer data is stored. Unfortunately you can't buy the boards separately from Toyota, but if you can track down one from a wrecked Yaris, which has a cluster with the same part number, then you can either swap the clock/odometer display onto yours or you can swap your core onto it.
#25 |
Yeah,but used clusters cost over 100$ on ebay,so it is a bit expensive.My dad is a electrician,so i wil disassemble the cluster and give him.Maybe he can find the problem.Anyway thank you for your response,i will notify you if i find something.
#26 | |
#27 |
Ok,i am interested,tell me how we gonna do this.But i still need to be sure where is the problem with my clock.Give me few more days to test it,then i am going to let you know.
#28 |
Here is the Pic of LCD.I was wondering this black spot in the right corner,is this ok.I mean I see on both of yours it is visible.Then again as i disassembled the speedo,it had also two of these marks,so i think this is ok.
#29 |
That black spot does appear to be a normal part of how they manufacture the VFDs.
Since it is custom I can't find a data sheet for it. It would have been good if I could so that we could take some comparative measurements to determine if that is what is bad on yours.
#30 | |
#31 |
The driver circuitry is actually on the bottom of the large board (where the large can shaped devices are). The small board on the back is the core board where the odometer data is stored and the main processor is located. I believe that that one is fine.
#32 |
Ok Scott,here on this pic you can see these three transistors or whatever they are,seems to be burned.You can tell by their middle pins.I have isnpected them with ohmmeter,and the current flows on both sides instead of one.They are type MK 58.So when I turned the cluster on the other side,you can see clearly brown spots on this green pattern.Can you confirm that this could be the problem.You can see them right in the bottom middle section.
#33 | |
#34 | |
And i need some characteristics for this type. |
#35 |
I am not sure. The MK alone is not enough information.
#36 |
Hey Scott,can you please help me with this transistor.I could not find nothing with this code MK 58.It has to be another name for it.
| GI: "YarGauge" replacement clock module (Digital Tach, etc.) | CTScott | Items for Sale by private party | 756 | 03-21-2013 08:22 PM |
| 05 Echo changing time on clock | jambo101 | DIY / Maintenance / Service | 3 | 11-12-2011 04:34 AM |
| Dashboard mount for iPhone 4S? | shima | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 10-25-2011 09:22 AM |
| Dashboard remove ... ALL of it | Toji | Cosmetic Modifications (Exterior/Interior) | 7 | 02-26-2011 06:30 AM |
| Setting the clock after DST change | ToddR | DIY / Maintenance / Service | 10 | 03-09-2009 11:33 PM |
