Old 04-08-2013, 06:47 PM   #19
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by yariSB86 View Post
I've heard bad things about the zage bov, was yours set low out of the box?
I was planning on tuning the F/IC myself and getting the actual car tuned professionally. Where I have yet to find >_<
How do you mean the F/IC yourself the actual car tuned yourself? If you are using an F/IC then that is what you are tuning (retarding timing, fuel maps, etc)
What else is there to tune?
Old 04-08-2013, 09:30 PM   #20
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Isn't the F/IC limited in what it can tune? Wouldn't I need to get the ECU remapped?
I was under the impression this would have to be done to get most out of the engine.
yariSB86 is offline   Reply With Quote
Old 04-08-2013, 10:36 PM   #21
fnkngrv
fnkngrv's Avatar
The Yaris ECU is locked and cannot be remapped. Your only option is to go full standalone. There are varying opinions on how effective using a piggyback is depending really on your goals.
Old 04-08-2013, 10:45 PM   #22
yariSB86
yariSB86's Avatar
I did not know that. Thanks.
How difficult is tuning with the F/IC if I were to do it myself?
Old 04-09-2013, 12:09 AM   #23
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
if you have an idea its not to bad, take your time, have a good scan tool.
Old 04-09-2013, 08:14 AM   #24
yariSB86
yariSB86's Avatar
I'm using the scan gauge II. I should be alright, hopefully. Lol.
Old 04-09-2013, 10:49 AM   #25
fnkngrv
fnkngrv's Avatar
have you ever owned or had any experience with turbo applications?
Old 04-09-2013, 11:35 AM   #26
Focus_Sh1ft
Focus_Sh1ft's Avatar
Very simple.
If you're just trying to make a boosted daily driver (I assume you are, otherwise you'd have went custom), you really won't need to tune anything else beyond afrs. If you're having predetonation problems, you'll want to do some work on ignition timing though. I run 93 octane and never have had predetonation.
Also, if you're tuning in open loop - you're pretty much required to know how to adjust the afrs. Big changes in weather will throw off your entire map. Example: It was in the 40's last week, and now it's in the 70's. I had to richen my entire map to compensate.
Old 04-09-2013, 11:54 AM   #27
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
The scangauge 2 is an awsome tool but I think you need something that is going to show you more stuff. I think the scangauge shows A/F in what the ECU is trying to achieve, not what it actually has. I think at the least you are going to need a good AFR meter...
(as a disclaimer, I am not boosted)
Old 04-09-2013, 12:02 PM   #28
fnkngrv
fnkngrv's Avatar
Also realize that every motor is different so even though someone might be able to give you a base set of maps to go from DO NOT just drop them in and call it a day. Even though you want to do it on your own is there a shop that you can become acquainted with that could assist you? Teach you the ropes?
Old 04-09-2013, 12:12 PM   #29
yariSB86
yariSB86's Avatar
Thanks for all the input guys.
Is $240 a good price for a set of 1zz injectors?
Old 04-09-2013, 02:47 PM   #30
kou
Drives: 08 lb
NO i found a set on ebay used fo $70
Old 04-09-2013, 07:20 PM   #31
fnkngrv
fnkngrv's Avatar
Are they brand new or used?
Old 04-09-2013, 09:30 PM   #32
yariSB86
yariSB86's Avatar
$240 was for brand new oem replacements. I found a better set for 150
Old 04-09-2013, 11:39 PM   #33
^ well done!
Old 04-10-2013, 06:25 AM   #34
yariSB86
yariSB86's Avatar
Thanks Garm! ;)
Old 04-10-2013, 10:48 AM   #35
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Following along, pretty much in the same boat as the OP (boost)experience wise with a pile of parts ready to go.
-Type 07 FFL-
My odometer 03/11
Old 04-10-2013, 11:14 AM   #36
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Damn. I wanna be in the boosted club. One day I will have my build thread.
Good luck on yours. I will be following it also
-Derrick-
List of Boosted Yarisworld Members - Redux CTScott Forced Induction Forum 40 06-29-2025 08:42 PM
List of Boosted Yarisworld Members whooppee777 Forced Induction Forum 262 11-23-2022 05:49 AM
Boosted Yaris Quarter Mile Times 1.5 Forced Induction Forum 0 01-03-2010 05:49 PM
Going Boosted FryGuy Forced Induction Forum 53 03-01-2009 10:01 PM
PE Boosted Yaris Video jinxor Forced Induction Forum 16 02-06-2009 02:33 AM
