Old 04-11-2013, 09:08 PM   #37
kc0rpm
Drives: 08 yaris sedan
Oh yeah, a 19mm crows foot. Can't torque the ball joint without one. I found that mine had dissapeared and had to borrow one from the neighbor
kc0rpm is offline   Reply With Quote
Old 04-11-2013, 09:12 PM   #38
kc0rpm
And as for parts stores having that seal, I can't even get a damn axle nut outside the dealer. My local parts stores carry nothing for the yaris except plugs, filters, and a special order axle. That's about it.
Old 04-11-2013, 09:33 PM   #39
YarisSedan
Drives: 08 Yaris Sedan
Dang forgot its different for other people who don't live in the bay area. Where I live theres probably about 35 part stores within a 20 mile radius. If you go to the dealer with the part numbers i listed then they should be able to get you the right part then no problem. Otherwise if you want to paypal me 5 bucks I can put one in a envelope with a stamp on it and send it your way.
Old 04-11-2013, 09:35 PM   #40
kc0rpm
Well I have a part sitting at the dealer right now just wasn't able to make it there today. Hopefully I will have more time tomorrow and we will see if the numbers match up.
Old 04-11-2013, 09:47 PM   #41
The part number you need is 90311-34042 for the left and 90311-34023 for the right Ishino makes it, it should be available at any local parts store not just the dealer. If you still cant get it let me know I have 5 in stock they are about 5 dollars each. (happen to work at a transmission shop)
From the EPC, I never would have guessed that 90311-34042 was that seal. 90311-34023 does make sense from the diagram though.
90311-34023
90311-34042
Old 06-10-2015, 06:55 PM   #42
MGBball11
Drives: 2008 Yaris Hatchback
Sorry if it's bad manners to resurrect a 2-year-old post. I'm a complete car novice, and a friend of mine is going to help me with a few repairs recommended by a local shop. I was told one of my output shaft seals is leaking. Should I get the parts mentioned by YarisSedan (90311-34042 for the left and 90311-34023 for the right)? I got a bit confused by the discussion about the dust cover versus the actual seal. Do I need to get both?
Any help would be appreciated!
MGBball11 is offline   Reply With Quote
Old 06-10-2015, 08:42 PM   #43
Correct - The parts listed by YarisSedan are the correct ones.
Old 03-06-2016, 04:28 PM   #44
likoulou31
Drives: Toyota Yaris
Hi everyone,
My output shaft seal from passenger side (right) is leaking.
I bought new 75W90 (2L of motul motylgear) for repair and I have to buy parts to fix this but i'm a bit confused I know that I have to buy the 90311-34023 (90311-W0003 for Toyota's stores in France).
What about the dust cover which is 41336D ? Do I have to buy a new one or it won't be necessary to replace it ?
The Output shaft seal is 43410M :)
Sorry for my english ;)
likoulou31 is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
