Old 03-21-2013, 02:39 PM   #1
kc0rpm
Drives: 08 yaris sedan
transmission oil seal
Does anybody know what the part number is for the drivers side axle oil seal on an 08 yaris sedan is? I can't seem to find anything online and my local dealer is not being very helpful. Thanks in advance. This forum is awesome.
kc0rpm is offline   Reply With Quote
Old 03-21-2013, 02:50 PM   #2
Left Side:
Automatic: 90311-34030
Manual: 90311-25028
Right Side:
Automatic: 90311-34031
Manual: 90311-34033
Old 03-21-2013, 03:01 PM   #3
kc0rpm
Awesome. You wouldn't happen to know where I could get the left my one online would you?
Old 03-21-2013, 03:10 PM   #4
kc0rpm
Oops, I meant left manual transmission
Old 03-21-2013, 03:11 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
http://www.rockauto.com/catalog/x,carcode,1441505
try this
Old 03-21-2013, 03:15 PM   #6
kc0rpm
Hmm...the only thing I see on there is an output shaft seal. Don't think that's what I'm looking for.
Old 03-21-2013, 03:21 PM   #7
fnkngrv
fnkngrv's Avatar
This is what they list for the Manual Tranny that they carry:
2008 : TOYOTA : YARIS : 1.5L L4 : Transmission-Manual
Clutch Hydraulic Hose
Clutch Kit
Clutch Master Cylinder
Clutch Release Bearing
Clutch Slave Cylinder
Input Shaft Repair Sleeve
Input Shaft Seal
Output Shaft Repair Sleeve
Output Shaft Seal
Shift Shaft Seal
Transmission Mount
Can you further identify what part you have to replace or that is non-funtional? Mayhaps even a photo or two?
Old 03-21-2013, 03:35 PM   #8
For OEM parts, TRDSparks.com or Toyotapartszone.com are the two I use.
Old 03-21-2013, 06:21 PM   #9
kc0rpm
Thank you Scott. Toyotapartszone had exactly what I was looking for.
Old 04-07-2013, 06:13 PM   #10
kc0rpm
So I ordered the left seal for the manual trans with the number above and after tearing my car apart it isn't even close to what I jeeded . what gives?
this is what I got
and this is what the old one looks like
Old 04-07-2013, 06:45 PM   #11
kc0rpm
Here is a better size comparison.
Old 04-07-2013, 07:22 PM   #12
The part you received is the actual axle seal, which keeps the fluid in. The outer part in your picture is the "dust cover" and is: 41336-12010
Old 04-07-2013, 07:37 PM   #13
kc0rpm
Ok, so how do I go about removing the dust cover without damaging it? There doesn't seem to be anything in the service manual about it.
Old 04-07-2013, 08:29 PM   #14
That is a very good question. I think a seal puller would be the right tool. I had a damaged one that I had to replace (and didn't have a set of seal pullers) and I completely chewed it up trying to get the bad one out.
Old 04-07-2013, 08:42 PM   #15
kc0rpm
All I have is a slide hammer and an old Mac seal puller. I wonder if pulling the inner seal and the dust cover as one unit would work. I just don't want to mangle that dust cover and have to wait for another part to come in.
Old 04-08-2013, 12:31 PM   #16
kc0rpm
OK, now this is starting to get frustrating. The only thing that is in that hole is what you call a dust cover
This little seal that I have doesn't appear anywhere. What gives?
Old 04-08-2013, 01:49 PM   #17
kc0rpm
Ok, so from what I can figure out the dust cover is actually part of the axle, not attached to the transmission. What I pulled out is the actual oil seal so the part that I have is not what I needed. Im not sure where it goes but I'm guessing that its either the input shaft or output shaft which is not what I am looking for so i guess its another trip to the dealer and wait another day for the correct part. Will post correct part number when I figure it out.
Old 04-08-2013, 02:03 PM   #18
It has been over 3 years since I did mine, and it was on an automatic. I am going by the electronic parts catalog. Here are the diagrams that I got the part numbers from:
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
