#55 |
Getting started!
#56 |
I can only feel 10% of your excitement.. I can only imagine yours.
#57 |
![]() Also digging the gauge pod. That's a pretty decent fit. Give us more pics!
#58 |
And so it begins.....
#59 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
Good luck!
Pls post more pics! |
#60 |
Thanks guys! burning and turning hard with this install.
have a couple questions regarding the boomslang pnp harness. first question is where does this inline fuse go(it is a 10amp fuse)? does it replace the 7.5 fuse labeled ECU-B? ![]() next question is, these two wires look kinda important and I just want to make sure if I need them or not. one is white with a blue strip, the other is brown with black stripe.
#61 |
Mr. 155 and climbing
iirc I used a spare slot for my BSlang...I can try and see if I can get you better info...I currently have mine disco'ed. Yes, I am running without management, but have dropped my MV-S spring to the 3.5psi one until I upgrade my management. All I can say as well is be really careful with the lock arms as mine broke after only a year and removing/installing the harness a half dozen times.
#62 |
^ Nope...can't recall where I plugged it in. Perhaps Focus or CTScott can chime in if they can recollect. Sorry.
#63 |
Alright next question.
For the oil return, if I am not using the zage oil pan, what is the best way for doing this return line? (drilling a hole in my engine is almost out of the question) |
#64 |
If you aren't using the Zage pan, drilling a hole and installing some fittings is the ONLY other option. Very nice pictures on our forums (and probably on here too).
#65 |
Damnit Garm :( I was afraid of that.
pm sent to you btw. |
#66 |
so back to this:
![]() its a wired in 10amp fuse pre wired on the AEM F/IC harness. where does it go? |
#67 |
I remember seing a totally awesome step by step pnp harness installation description on the MI web-site (done by guess who )))))))
#68 |
#69 |
Turbo kit is installed.
Still need to: Cut some plastic around intercooler piping Tap the block for oil return... Add oil (Man my brain is fried, been working on this from 10am through 11pm.) can't think right now...going to bed. |
#70 | |
As for where it goes, you have quite a few options at the fuse box in the engine bay. Ideally, you'll want to hook it up in place of another 10 amp fuse that only receives power on ACC or IGN. I'd check ECTS and EFI2 to see if they have voltage on key off, I can't remember. Even if you have a constant 12v, the FIC has very little parasitic drain (pretty sure I actually have mine hooked up to a constant 12v). Also, drilling the block - not as daunting as it sounds. Use the fittings I have in my guide, seal it up with some permatex, and you'll be fine. Keep it up! It's worth it in the end
#71 |
Thanks focus. The fuse went to efi.
Gotta go shopping today, don't have the right drill for this. |
#72 |
![]() ![]() Drives: Axio GT Join Date: Apr 2012
| List of Boosted Yarisworld Members - Redux | CTScott | Forced Induction Forum | 40 | 06-29-2025 08:42 PM |
| List of Boosted Yarisworld Members | whooppee777 | Forced Induction Forum | 262 | 11-23-2022 05:49 AM |
| Boosted Yaris Quarter Mile Times | 1.5 | Forced Induction Forum | 0 | 01-03-2010 05:49 PM |
| Going Boosted | FryGuy | Forced Induction Forum | 53 | 03-01-2009 10:01 PM |
| PE Boosted Yaris Video | jinxor | Forced Induction Forum | 16 | 02-06-2009 02:33 AM |
