Old 03-29-2013, 08:55 AM   #1
sant_ashu
Drives: toyota yaris 1.0 t3 2004
Exclamation Gear Pops /slips/ jumps out to neutral
Hello Guys,
I had a problem yesterday while i was going on dual carriageway @50-60mph
when my fifth gear pops out to neutral. I pressed the clutch and engaged it again. And again after couple of mins it pops out again. And then i engaged it again and it did not pops out.
I had earlier an issue week or 2 before when my 4th gear was popping out to neutral. and it was maily duing city driving. And i thought it could be due to gear oil not being hot enough. As the Blue engine light was still on.
there are few links i found about the issue:
http://www.wcengineering.com/articles/popout.html
http://wiki.answers.com/Q/Why_would_...ip_out_of_gear
as these are more general ones not specific to yaris so
I just want to know if any yaris owner had this issue before and what was the reason, or how did they sort that out.
Cheers
sant_ashu is offline   Reply With Quote
Old 03-29-2013, 01:41 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
The first link you posted pretty much covers it. Start by checking the linkage. Have someone in the car shift the linkage through the gears (with engine off). Have them put it in 5th, then try to move the shift lever on the transmission further. If you can, then it's likely the linkage is worn and you are not getting it all the way into 5th.
If it is internal, chances are it is best to just drive the car until it breaks or won't stay in gear. Then replace the entire trans with a used one. If you have a friend who can rebuild transmissions, it might be worthwhile but otherwise replacing is going the be most cost effective.
I have never heard of a Yaris doing this, but it can happen to anything.
Cheers.
Old 03-29-2013, 09:26 PM   #3
sant_ashu
Thanks CoryM. Could you please (post a pic ) or explain bit more so that i can understand what u mean by "
try to move the shift lever on the transmission further"
Sorry for my little knowledge.. i am just diving into the field of DIY..
Old 03-30-2013, 08:26 AM   #4
bronsin
bronsin's Avatar
When I was a VW mechanic in the 70s popping out of gear meant your transmission needed rebuilding....
Old 04-01-2013, 12:34 PM   #5
sant_ashu
Hello Guys,
I noticed that there is a open vent on the transmission mount that shows some oil drops !! and also there is some oil splashes on the plastic under the radiator just infront of tranny. could be from the same vent. is that a problem?
Also some people mentioned on internet to check the tranny oil level:
http://www.autos.com/car-maintenance...-how-to-fix-it
So how to check the tranny oil level (there is no dipstick!!!!)
Thanks
Old 04-01-2013, 12:39 PM   #6
kou
Drives: 08 lb
There are two plugs on the trans one lower for draining one mid way up for filling, the fluid has to be just under the fill plug.
This will give you an idea not the same car but same theory.
http://www.toyotanation.com/forum/13...id-change.html
Old 04-01-2013, 02:33 PM   #7
sant_ashu
thanks kou, from the links it looks like the open vent is actually fill hole . but there is no plug its open when I bought it.( 4 weeks before only), do u think its normal? or there should be always plug to keep it close?
just another link to save in the post
http://www.toyotanation.com/forum/13...hange-diy.html
Old 04-01-2013, 02:36 PM   #8
kou
Drives: 08 lb
There should be a plug. Can you post a picture? This is where they are on my trans.
Old 04-01-2013, 06:04 PM   #9
sant_ashu
thanks kou. Here are the pics.
https://docs.google.com/file/d/0BxtH...it?usp=sharing
Old 04-04-2013, 06:50 AM   #10
sant_ashu
Hi Guys, I figured out the open vent is actually fill hole and it was missing the fill plug.
As i bought the car recently ( 4 weeks before) and it was fine for 2-3 weeks i am thinking it has leaked some gear oil and starting to cause issues, so doing the gearbox oil change will sort the probem (lets see will update when its done)
So is there any filter for the gearoil fileration? and is it making sense to change that as well?
Let me know.
GRADE: TRSTD: STANDARD TYPE (02/2003- )
PRODUCT: FRP: PRODUCED AT TMMF
DRIVER'S POSITION: RHD: RIGHT-HAND DRIVE
ENGINE: 1SZFE: 1000CC 16VALVE DOHC EFI
TRANSMISSION: MTM: MANUAL TRANSMISSION
GEAR SHIFT TYPE: 5F:MTM, 5-SPEED FLOOR SHIFT
NO.OF DOORS: 3D: 3-DOOR
COLOR CODE: 1E7 TRIM CODE: FC11
Old 04-04-2013, 07:04 AM   #11
bronsin
bronsin's Avatar
The fill plug was missing?
Serious stuff!
I doubt there is anything you can do except rebuild the transmission or get one in a junk yard.
But I might be wrong.
Old 04-05-2013, 07:44 AM   #12
sant_ashu
Serious stuff!
Well I am trying the cheapest solution first ie to change the gearoil and fill it upto optimum level. if that does not work then i will think of getting the one from junk yard.
But my question is if there is any filter that needs to be changed as well during gearoil change??
Old 04-05-2013, 10:37 AM   #13
bronsin
bronsin's Avatar
No there is no filter.
You are right change the oil. You might find metal flakes in the oil. Or you might not. Not is good!
One trick we used to do with a transmission making noise/popping out of gear was change the oil and add a tube of molybdenum additive.
But change the oil and DRIVE THAT SUCKER! If it still pops out of gear my experience (with old VWS) tells me the trans will eventually go. But that might be a long time from now. In the meantime you can further evaluate the car too see if you want to put more $$$$ into it. And find a transmission in a junk yard.
Good luck!
Tell me what happens!
Old 04-05-2013, 04:10 PM   #14
sant_ashu
Thanks Bronsin.
do you have any product code/brand etc for this additive "add a tube of molybdenum additive.", and how much you recon to add?
Also there is another link i found about the gear pops:
http://www.mr2.net/trackdayqueen/fithgear.htm
But donot know if the 5th gear is also accessible similarly in yaris?
Old 04-05-2013, 04:49 PM   #15
bronsin
bronsin's Avatar
Thanks Bronsin.
Hmmm Im in the US so I have a feeling things sold here wouldnt be sold where you live. I would google molybedum additive and see what shows up.
Or ask at a local parts store for the same.
Old 04-29-2013, 06:15 PM   #16
sant_ashu
hey guys,
just to update the thread, I changed the gearbox oil and put the missing fill plug.
and from one week so far I have not had a single time a gear slip or popping into neutral.
so moral of the story it was low gear oil that was causing the gear popping to neutral.
thanks everyone for your suggestions.
Old 04-29-2013, 07:33 PM   #17
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
missing fill plug? OMG...
B2FiNiTY is offline   Reply With Quote
Old 04-30-2013, 07:24 AM   #18
bronsin
bronsin's Avatar
hey guys,
Awesome.
How that fill plug got out though would make a good story. Ive never seen or heard of that.
gear pop jump neutral
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 09:16 AM
Remote Start Problem: Mechanical, Like in Gear Lil Abner DIY / Maintenance / Service 10 07-24-2011 07:49 PM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 02:30 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 12:51 PM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 03:23 AM
