Old 04-05-2013, 06:44 AM   #12
sant_ashu
Drives: toyota yaris 1.0 t3 2004
The fill plug was missing?
Serious stuff!
I doubt there is anything you can do except rebuild the transmission or get one in a junk yard.
But I might be wrong.
Well I am trying the cheapest solution first ie to change the gearoil and fill it upto optimum level. if that does not work then i will think of getting the one from junk yard.
But my question is if there is any filter that needs to be changed as well during gearoil change??
GRADE: TRSTD: STANDARD TYPE (02/2003- )
PRODUCT: FRP: PRODUCED AT TMMF
DRIVER'S POSITION: RHD: RIGHT-HAND DRIVE
ENGINE: 1SZFE: 1000CC 16VALVE DOHC EFI
TRANSMISSION: MTM: MANUAL TRANSMISSION
GEAR SHIFT TYPE: 5F:MTM, 5-SPEED FLOOR SHIFT
NO.OF DOORS: 3D: 3-DOOR
COLOR CODE: 1E7 TRIM CODE: FC11
sant_ashu is offline   Reply With Quote
Tags
gear pop jump neutral
Experimenting with bypassing the AT 4th gear prohibition when cold CTScott Performance Modifications 28 03-22-2015 08:16 AM
Remote Start Problem: Mechanical, Like in Gear Lil Abner DIY / Maintenance / Service 10 07-24-2011 06:49 PM
Toyota C160 Reverse Gear Problem Parmas DIY / Maintenance / Service 2 12-01-2010 01:30 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
New Owner - Lights on Gear Shift javagirl New YARIS Purchase Forum 8 05-22-2009 02:23 AM
