![]() Drives: 08 3dr LB Join Date: Feb 2013
Blower motor? "Here we go again"
Ok. The blower motor stopped working yesterday. First time since I purchased car. I opened the cabin filter to look for blockage. None found. Then I turned the cage by hand, and it started working fine. Now today "hot as fire in Georgia"
It stops again? So I open the fresh air vent, then drove to highway speed to see if outside air would move motor enough to start! It did. Now ? How much trouble to change out blower motor? Let me guess. Pull engine and transmission, also rear tires ![]() Any idea of motor cost? |
Remove the bottom plastic panel there should be a few screws and it comes out. Should take less than 20 minutes from start to finish.
Thank you sir! I will try this tomorrow if dealer stocks motor?
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
I took out my son's blower and unplugged and lubed it with WD40. Put it back.
I was told that I should of used silicone instead but it is working now and has been for a few weeks. |
| A/C Blower Dismantling? | Yaross | DIY / Maintenance / Service | 9 | 12-14-2011 03:56 AM |
| Why wont my fan blower work? | lucy7509 | DIY / Maintenance / Service | 4 | 08-09-2011 02:48 AM |
| 09 Yaris Heater blower problem | motoxxx3 | DIY / Maintenance / Service | 28 | 10-15-2010 05:45 AM |
| A/C blower resistor | ubear7 | DIY / Maintenance / Service | 1 | 08-08-2010 09:53 PM |
| dead mouse in my blower unit | beacon | DIY / Maintenance / Service | 20 | 11-25-2008 12:31 PM |
