Old 05-14-2013, 12:59 PM   #19
TOLMACH
Drives: soarer
Was it orange originally? (like below except mph vs kmh)
http://photo.qip.ru/users/tolmach/96608749/127200152/
Old 05-14-2013, 01:43 PM   #20
Yes. It was an orange one to begin with.
I checked my Canadian one that I have in Crashy2 (with my demetricifier, which makes it read in miles instead of kilometers) and it would end up looking just like that one. I am trying to decide what color I want to change it to and once I do I'll post a pic of it modded as well.
Old 05-14-2013, 02:50 PM   #21
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
What about the S model in the sedan?
Old 05-14-2013, 03:04 PM   #22
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Is your cluster different than mine?
Old 05-14-2013, 03:21 PM   #23
If it looks like the one above the white areas can become the new color, but the outer blue band will remain.
Old 05-14-2013, 03:55 PM   #24
fnkngrv
fnkngrv's Avatar
yep...
Old 05-14-2013, 06:33 PM   #25
^What does that one look like when it is lit?
Old 05-15-2013, 09:54 AM   #26
Someone from Australia asked if I could change the digital display cluster, and it looks like the answer is YES:
Old 05-15-2013, 03:07 PM   #27
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
Totally wish I could change the color on my 2013. It would look better red or blue than orange. >_>
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 05-15-2013, 04:18 PM   #28
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Cross fitment between the MT sedan and MT hatch cluster? I can't find a MT hatch with tach...on ebay anyways.
-Type 07 FFL-
My odometer 03/11
Old 05-15-2013, 04:36 PM   #29
Kar98
Drives: 2011 Scion tC
Yeah, manual transmission with tach, for hatchbacks would be nice.
Old 05-15-2013, 05:19 PM   #30
fnkngrv
fnkngrv's Avatar
I will have to take a couple snaps this weekend for you.
Old 05-15-2013, 05:19 PM   #31
fnkngrv
fnkngrv's Avatar
I have always thought that the orange they use is reason to
Old 05-15-2013, 07:24 PM   #32
Sedan ones are a slightly different shape, so it is a no go. I have been scouring my sources for a tach one for you and am coming up empty. One option would be to buy a Canadian one and use one of my Demtricifiers, which intercepts the speed signal to it and makes the outer ring be MPH instead of kmh and also makes the odometer increment in miles rather than km.
Old 05-15-2013, 07:24 PM   #33
The 2013 is doable as well.
Old 05-15-2013, 08:08 PM   #34
Mine is the same white faces brushed aluminum look as fnkngrv's.
Old 05-15-2013, 08:41 PM   #35
mazilla
advocatus diaboli
mazilla's Avatar
I had anticipated using the Canadian version with the demtricifier, empty handed there too...if you can find one I'm good with it. I want my boost gauge where my cheapo aftermarket tach is so the tach in the factory display would be ideal.
-Type 07 FFL-
My odometer 03/11
Old 05-15-2013, 09:34 PM   #36
They are suddenly hard to find as well. There is one 2008 LB one on ebay, but it is an ABS one, and my experience with pre-09 clusters is that if you run an ABS one on a non-ABS car, the speedometer does not move (but with an 09+ ABS one on a non-ABS car the speedo does work).
change, cluster led, color, speedometer, tach
WTD: ECM, Instrument Cluster, Headrests, Quarter window chrisjaldin Willing to Buy by private party 8 09-02-2011 11:12 PM
Cruise Control - 07/08 Sedan - Instrument Cluster CB900F2 DIY / Maintenance / Service 4 02-23-2011 07:03 AM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 09:53 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
