Old 05-08-2013, 01:38 PM   #1
Custom Instrument Cluster LED Color Change Service
I have done LED color changes for a couple of people recently, so I figured I would go ahead and open this service to the rest of the community. The 09-11 clusters are the best for modifying, as the speedometer is a single color, fed only by the LEDs. The 06-08 clusters have some either red or blue trim printed into the plastic, so that portion will not change color.
I can standard colors, like white, blue or red, or I can do a wide variety of custom colors, using a trick that I figured out for also being able to change the color of the clock (on non-tach cluster) to match (as the clock uses a VFD display, rather than LEDs). So, almost any color you can imagine I can do.
If you are relatively local, we can schedule it where I do it while you wait (it takes about an hour or so for me to do one). If you are not local, you can either pick up an extra cluster off ebay for me to mod, or I can potentially mod one of my extra ones and have you ship your original one back to me. I can also reprogram the odometer for an extra fee, so matching your mileage on a swapped cluster is not an issue.
Cost (+ return shipping, which typically runs under $15 within the US):
Color change only: $100
Odometer reprogramming only: $50
Color change and odometer reprogramming: $125
Here are some samples:
Blue:
White:
Custom Violet:
Custom Green:
Old 05-08-2013, 02:07 PM   #2
TOLMACH
Drives: soarer
Wow!
1. Can you change colors on canadian cars (2009) with separate speedometer and tach?
2. Is there a way to change the color of tach only to red and leave spedometer as is?
Thanks
Old 05-08-2013, 02:23 PM   #3
Astroman
Modded Moderator
Astroman's Avatar
Cool!!
Old 05-08-2013, 02:31 PM   #4
Originally Posted by TOLMACH View Post
Wow!
Thanks
Yes, Canadian clusters are doable as well and I am 90% sure that I can change the tach color separately from the speedo.
Old 05-08-2013, 02:34 PM   #5
TOLMACH
Drives: soarer
Wow again ))
Will spend some time thinking what I want (I do know that I do not like the stock color but do not know yet what I want) and revert to you.
I can drive without this thing, right?
Thanks
Old 05-08-2013, 02:40 PM   #6
Wow again ))
Thanks
You can. If you have a ScanGauge, it can act as your speedo and tach, so you are not driving blind.
Old 05-08-2013, 04:01 PM   #7
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Can we put an 09 directly into an 07? I forget if there is a difference at the moment...
-Type 07 FFL-
My odometer 03/11
Old 05-08-2013, 04:03 PM   #8
YarisSedan
Drives: 08 Yaris Sedan
I like the white one it has a real clean and stock look.
Old 05-08-2013, 04:10 PM   #9
Yes. The ABS light (and TRAC and VSC) will stay lit if you install an 09-11 in a 06-08, but I can disable those lights, while I am inside the cluster.
You know you want a purple one to go with that nice rainbow sparkle paint!
Old 05-08-2013, 04:21 PM   #10
mazilla
advocatus diaboli
mazilla's Avatar
Hmmm, I just might have to take you up on that offer(not the purple part, hahaha). I'm digging that white, would change all my green over to match. I'd need the seatbelt signal and any airbag lights disabled as well, save me some electrical tape. Hehe
-Type 07 FFL-
My odometer 03/11
Old 05-08-2013, 06:15 PM   #11
B2FiNiTY
B2FiNiTY's Avatar
Drives: Prius C
looks really good!
B2FiNiTY is offline   Reply With Quote
Old 05-10-2013, 07:45 PM   #12
screenprintr
screenprintr's Avatar
Drives: 2010 Toyota Yaris
You changed the LED in each just for the picture?
screenprintr is offline   Reply With Quote
Old 05-10-2013, 10:48 PM   #13
I have done a few, but didn't take pictures, so since I had extra LEDs from those conversions, I did swap them three times just to take pictures of the colors I have done.
Old 05-11-2013, 10:53 PM   #14
Melloreel
Drives: 08 3dr LB
Hey Scott. Off topic. Can I put a cluster with tach into my 08 which only has speedo? Would I have to run new wire, or like the cruise, plug and play?
Melloreel is offline   Reply With Quote
Old 05-11-2013, 11:04 PM   #15
It is plug and play as long as you match if your car has ABS. If you don't have ABS, that limits you to 08 and older clusters. You can use 09 and newer ones, but some of the indicator lights (ABS, TRAC, VSC) will stay on, unless you internally cover or remove them.
Old 05-11-2013, 11:27 PM   #16
TOLMACH
Drives: soarer
^ Based on the above pictures - it looks like the process of removing the cluster itself is not very difficult? Just several screws and a jack on the front panel? No cables from the back side?
(Removal of the surrounding plastic pieces is easy)
Thanks
Old 05-11-2013, 11:52 PM   #17
Thanks
Yes. It is that easy - Pop the cluster trim off by pulling it back (being careful not to snap the little fingers that latch into the top of the radio time), Remove the two mounting screws that go into those L shaped feet on the front, undo the two connectors, and lift it out.
Old 05-14-2013, 01:50 PM   #18
Here's a cobalt blue one with odometer correction just completed for bladesmith6 (it had 58xxx on it when he purchased it).
change, cluster led, color, speedometer, tach
WTD: ECM, Instrument Cluster, Headrests, Quarter window chrisjaldin Willing to Buy by private party 8 09-03-2011 12:12 AM
Cruise Control - 07/08 Sedan - Instrument Cluster CB900F2 DIY / Maintenance / Service 4 02-23-2011 08:03 AM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 11:05 PM
Instrument Cluster Swap thepaidtraveler Cosmetic Modifications (Exterior/Interior) 28 11-24-2008 10:53 AM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 11:22 AM
