Old 04-19-2011, 04:54 PM   #1
vacuum hose / heater hose size
What size is the stock Yaris vacuum and heater hose? I.D.
Thanks
Old 05-16-2013, 08:47 PM   #2
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I know this thread is 2 years old, but I've been needing to know this. I took a pair of calipers and measured the ID of the hose that goes from the valve cover to the intake manifold and it came out to 18.6mm. I found 19mm (3/4") hose online, but I'm not sure if this will work. My hose is leaking and I'd like to get a hose that doesn't have that weird insulated coating around it that I can get a proper hose clamp on instead of that piddly little metal clip.
Ideas? Opinions?
This is the hose I was looking at: http://www.amazon.com/gp/product/B00...1&s=automotive
As you can see this one is pretty expensive, so I don't want to buy it and it not fit.
Old 05-17-2013, 11:58 AM   #3
47_MasoN_47
Has noone replaced this hose with a non-factory part?
Old 05-17-2013, 12:04 PM   #4
kou
Drives: 08 lb
3/4 hose should work
Old 05-17-2013, 12:34 PM   #5
I can't seem to find the thread, but a while back someone asked the same thing and I posted the measurements. Rather than measuring the existing hose, measure the nipple that it will go onto at a point other than the flared area.
Old 05-17-2013, 12:58 PM   #6
47_MasoN_47
Yeah I had asked you at one point over on MI I believe, but I never could find that thread either.
Old 05-17-2013, 02:46 PM   #7
TOLMACH
Drives: soarer
Ideas? Opinions?
5/8 hose is the one that you need.. just ask for one in the nearby automotive store.. very cheap stuff
Old 05-17-2013, 04:15 PM   #8
47_MasoN_47
Thanks Tolmach.
Would silicone be okay to replace that valve cover to intake hose with? I read that silicone isn't safe for oil. I'm not sure how much oil goes through that hose but I know there is some, because it's all over my supercharger throttle body tube thing.
Old 05-17-2013, 04:43 PM   #9
kou
Drives: 08 lb
It will fail early as oil will soak into it. And a lot of oil blows in to the intake that is why mine is blowing into the air, mmmm the sweet smell of oil.
Old 05-17-2013, 05:06 PM   #10
YarisSedan
Drives: 08 Yaris Sedan
Mine is silicon and has been on there for about 3 years so far its held up.
Old 05-17-2013, 05:32 PM   #11
TOLMACH
Drives: soarer
Thanks Tolmach.
Do not know.. I am just using cheap regular one ))
Old 05-17-2013, 09:28 PM   #12
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
My Weapon R intake tube came with a silicone hose and I've had it on for about 9 months with no issues. No softening, no swelling, no discoloration, no deterioration. Now that you mentioned it, I'll keep a close eye on it for any changes and will post them if anything happens.
Old 05-17-2013, 10:58 PM   #13
47_MasoN_47
Even though they don't look as nice (I really wanted some pretty blue hoses haha) I went ahead and just got a regular ol black piece of heater tube. It was $5 for 2 feet of it and a couple of steel hose clamps.
Radiator hose size window_lee General Yaris / Vitz Discussion 0 03-31-2009 07:33 AM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 05:15 PM
Coolant Hose Size Question vasilios DIY / Maintenance / Service 2 06-27-2007 10:45 AM
