#1261 |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
I believe the above one is something similar to what weapon builds for xb http://www.ebay.com/itm/WEAPON-R-INT...6d3e2b&vxp=mtr |
#1262 | |
play every day
#1263 | |
He's added NOS ports and a different flange to it.
#1264 |
play every day
#1265 |
^ Sorry I missed you today, tooter.
#1266 |
play every day
#1267 |
^ I can always drop it off as well.
![]() thanks, the big 'ol Nash barn find has been a real fun project.
#1268 |
play every day
Picked up the intake from MI. When I removed the plastic wrapping, I saw that the tube had a manufacturing defect which had nothing to do with either shipping, or Jeff or Garm so I'm dealing directly with Injen.
![]() The tubing was crumpled where the machine gripped it to swedge down the MAF sensor area. Why they went ahead and polished the dents and sent it out is beyond me. Adrian, at customer service is making it right by sending out a good tube that isn't crumpled. ![]() Got the tooter et back from Bill at Ajax Welding... ![]() Now I can mount it on the engine to locate the proper attitude of the throttle body base/bellmouth in relation to the hemisphere. That manifold on ebay ended up selling for just $250 including shipping which is a pretty good deal for an alloy intake. |
#1269 |
play every day
Put the tooter et mockup on the engine to position the throttle body.
Because the plenum is a hemisphere, the throttle body is free to be rotated and angled in any direction. ![]() ![]() I also installed the stock air box as an alignment tool to precisely line up the body for a good fit.
#1270 |
2ZR swap. DO IT! Ask how!
Genius! I'm still curious about how the hemisphere will be mated to the manifold. Or did you cover that already?
#1271 |
Beautiful work! Does it come with a sound clip?
#1272 |
play every day
This is the next step... punch a hole to insert the bellmouth.
![]() ![]() Hey Cranky, ![]() The plan is to get a round piece of 1/8th inch aluminum plate to fit the hemisphere, and cut out the rounded square shape of the runner retainer. There will be two welding steps. First, weld the plate onto the manifold runner retainer, and then weld the hemisphere onto the plate. I'll also be inserting three aluminum tubes where the blue dots are for the hoses, so they'll also need to be welded into place. Last edited by tooter; 06-02-2013 at 10:25 PM. |
#1273 | ||
#1274 | |
play every day
![]() The manifold will be a lot more compact because a hemisphere is the most volume efficient shape for a plenum. This will move the throttle body to the left which is closer to its original stock location. I'm totally curious as to what the effect will be as there are no flat surfaces for the reflected pulses from the mouths of the runners to bounce off of. The entire inner surface of the plenum, including the 180 degree rounded bellmouth of the throttle body bore, is 100% curved. I just gotta find out what will happen. And the sales of the tooter products have bought the freedom to explore...
#1275 |
![]() ![]() ![]() Drives: '08G2T Prius Join Date: Oct 2012
Very cool build!
#1276 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
<--this guy is a alien sponser lol
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#1277 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
does it look phallic for Garm yet? :P
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#1278 |
![]() Drives: 2010 Yaris S HB Join Date: Nov 2011
subscribed
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
