Old 06-06-2013, 07:22 AM   #1279
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Is it welded together yet?
Old 06-06-2013, 10:16 AM   #1280
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Not yet. Right now I've got work piled up to the moon, so the manifold is on the back burner until I can get caught up.
Old 06-06-2013, 06:09 PM   #1281
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
238,900 miles (384,400 km), that is a lot of work is it all paper work?
Old 06-06-2013, 07:22 PM   #1282
^ Plus the thing about being able to breathe.
Old 06-07-2013, 01:08 AM   #1283
tooter
play every day
tooter's Avatar
No, I don't do paper.
I'm a sparky.
Old 06-07-2013, 01:24 AM   #1284
tooter
play every day
tooter's Avatar
Hey Garm,
Injen sent out a good replacement tube, and the intake looks great!
It was late so I only got to run it to see if there would be a CEL. No light.
Old 06-07-2013, 11:03 AM   #1285
Looks great - I like the little shield.
Old 06-07-2013, 11:56 AM   #1286
tooter
play every day
tooter's Avatar
I do too.
The design is very simple and direct. It's a whopping 3 feet long and actually very quiet. It's also easy to move around if I start messing around with the intake manifold.
Check out the header. LCE makes a really neato design that folds a long tube header into exactly the same space as the stock header. It fits like a glove!
Old 06-07-2013, 12:47 PM   #1287
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
^^^ RE: "long tube header" - Please forgive this noob question, it really is a question and not a troll, but why does it matter the length of a pipe? Don't you want the exhaust to just get out via the back of your car rather than in the engine bay?
Old 06-07-2013, 01:35 PM   #1288
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Not my wording but makes sense:
Exhaust headers with equal length tubes have been shown to develop slightly more power on an open exhaust system, but not when hooked up to a street system with mufflers. Fact is, most street motors with shorty headers will produce the same power as they would with expensive equal length headers.
Equal length tubes can produce more power, but they have to be the right length for the specific motor at the RPM range where you want the power. What that means is lots of custom fabrication and dyno testing, which translates into lots of time and money.
For racing applications, the slight gain may justify the cost, but competition cars can be more easily built "around the engine" than street cars. When you're working within the confines of a given body style and chassis, with motor mounts, starter, steering linkage and accessories to think about, the way the headers fit become more important.
That's where the compact or "shorty" style header shines. You get a significant performance increase compared to stock exhaust manifolds, at an off-the-shelf price..
JustDidIt is offline   Reply With Quote
Old 06-07-2013, 01:37 PM   #1289
Remove your header and see how much power you lose with no exhaust at all. A LOT.
Old 06-07-2013, 01:49 PM   #1290
7:34pm
Drives: 07 Yaris
Hey Garm,
What vehicle is this?
7:34pm is offline   Reply With Quote
Old 06-07-2013, 03:52 PM   #1291
TOLMACH
Drives: soarer
^ That is his yaris
Old 06-07-2013, 04:03 PM   #1292
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I can attest to that
Old 06-07-2013, 05:34 PM   #1293
Shinare
Shinare's Avatar
Well that's strange, I never would have guessed that would even affect the performance of a car. So exhaust pipes on the header make the engine work better rather than having nothing there to restrict... to me that's just really weird, hehe
Old 06-07-2013, 07:09 PM   #1294
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's all based on the Helmholtz principle, the Bernoulli effect and fluid velocity. Lots of crazy physics and maths to explain it, but not really relevant unless you're into that sort of thing. Here's my understanding of it: escaping exhaust pulses down each tube (Helmholtz), drawing a slight vacuum on the adjacent tubes (Bernoulli). Velocity and pressure of a fluid in a tube is decreased by increasing the diameter. Decreasing the pressure means easier flow, but lower velocity and less scavenging effect...I think.
Old 06-07-2013, 09:36 PM   #1295
tooter
play every day
tooter's Avatar
It's my 2012 Toyota Tacoma. I'm a forever diehard loyal Toyota owner.
Old 06-07-2013, 09:39 PM   #1296
tooter
play every day
tooter's Avatar
I just got it because it looks really neato.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
