![]() Drives: 2007 Yaris Sedan Join Date: Mar 2013
Broken Alternator Clip
I've been lurking this forum for a year and finally have a reason to post.
I was recently adjusting my alternator due to my serpentine belt having a squeak. While doing so, I broke the base of the clip that goes onto the engine. I believe it may be a ground wire. Has anyone ever done this, if so is there a diy fix or is this something I would have to bring it the dealer for. I come from a 2jz/rb25 background. Working in such a tight space is bit new to me.
![]() ![]() ![]() Drives: 2010 Toyota Yaris Join Date: Nov 2012
Get some Duct tape! JK.
Contact the Autoparts store. |
That's not a ground, it is the connector for the Oil Control Valve of the VVTI. It is a common and expensive mistake made while changing the belt.
#4 | |
Since it is the end that connect to the engine, advance auto, autozone seem not to carry it.
When you say expensive, what would be the ball park of having this repaired. |
#5 | |
I did that recently also lol. it cost me 105 dollars, and 5 minutes for me to fix :)
~Now with more road noise and less functionality! Last edited by mr_miles; 06-10-2013 at 07:07 PM. |
#8 | |
I was planning on doing it myself, but things went from bad to worse. I lost the top alternator belt in the engine bay and I cannot get the bottom alternator bolt back in. I'm gonna drop the yaris off at the dealer, they said they will charge me 1hr to put it all back together. The funniest thing about it was, the tech who helped identify the part, immediately knew how I broke it. Must be a common thing. |
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
Very common
I almost broke my son's but I stopped before it was too late. There are quite a few for sale on e-bay, so you know there is a market. It is in the worst place for belt tightening. Good luck.
Anyone have the P/N for it? Might order me one for my 2008 Hatch as a spare...
on ebay
$68 shipped gets this real Toyota part....
I need to change my belt. Mabye ill pull that sensor even before I attempt it..
No need to pull it. Once you realize its presence, it is very easy to deal with the belt without hurting it.
I know that bottom alt bolt comes in at 40lbs ft and is hell to loosen. After doing my first belt change I left it at 20 and it hasn't shifted a bit. Will be a lot easier next time. I do recall pressing against that sensor and almost breaking it myself. Good to hear from ya CT:)
#15 | |
bolt
?? So is there a special tool to use to avoid breaking that VVTI sensor ? anybody? |
lol
| Replace broken mirror glass? | Eatoman | DIY / Maintenance / Service | 5 | 11-27-2015 10:52 AM |
| Broken broken aircon pump pulley + dual mass crank pulley | Bluecatcottage | DIY / Maintenance / Service | 1 | 03-31-2013 07:55 AM |
| How to replace a broken wheel stud | Rami yaris | DIY / Maintenance / Service | 4 | 06-28-2012 05:34 PM |
| WTB: Broken iPhone 4/4S with broken screens or backs, missing/broken buttons | Black Yaris | Willing to Buy by private party | 0 | 02-22-2012 01:46 PM |
| Broken 40/60 Back / Rear Split Seat Handle / Lever | alex_melodymaker | DIY / Maintenance / Service | 9 | 10-31-2009 04:55 AM |
