#1 |
![]() ![]() Drives: '07 Yaris 5dr HB Join Date: Aug 2010
Replace broken mirror glass?
Hello Yaris World! I searched the forum but couldn't find much. After finishing work on Friday, I went to my car in the parking lot, and found that someone parked next to me had backed up and broken my passenger side mirror!
The housing has not been damaged, just the mirror is broken. Is this an easy fix? It's a power mirror (which is still operational). Is the mirror glued on or is it held on by clips? Can I find a replacement mirror for under 30$? Thanks!! |
The glass is glued to a plastic backing that has clips. Rotate the mirror towards the sky, stick your fingers under the bottom and pull straight out to release the bottom clip. Then, lift the top up and it will come right off.
OEM replacements from the dealer are about $35.
#3 |
Thanks CTScott! Does the OEM mirror from the dealer come with the plastic backing + clips, or do I have to be careful not to damage anything when removing the glass?
#4 |
With the backing, so you just have to snap it back on.
#5 |
Awesome! Thanks for the quick reply!
I really appreciate the help! |
#6 |
Drives: Yaris TR Join Date: Oct 2015
Thank from me as well.
| Tags |
| glass, mirror |
| How to replace a broken wheel stud | Rami yaris | DIY / Maintenance / Service | 4 | 06-28-2012 05:34 PM |
| WTB: Broken iPhone 4/4S with broken screens or backs, missing/broken buttons | Black Yaris | Willing to Buy by private party | 0 | 02-22-2012 01:46 PM |
| CVT fluid replace???? | tyrone_yaris | Asia | 3 | 02-19-2012 02:33 AM |
| LEDs to replace interior lights: Which ones? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 57 | 04-28-2010 01:44 PM |
| Broken 40/60 Back / Rear Split Seat Handle / Lever | alex_melodymaker | DIY / Maintenance / Service | 9 | 10-31-2009 04:55 AM |
