Old 06-07-2013, 10:48 PM   #1297
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
Originally Posted by tooter View Post
Nice wheels!
Old 06-07-2013, 10:59 PM   #1298
^ he puts them on everything.
Old 06-07-2013, 11:15 PM   #1299
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Originally Posted by Shinare View Post
^^^ RE: "long tube header" - Please forgive this noob question, it really is a question and not a troll, but why does it matter the length of a pipe? Don't you want the exhaust to just get out via the back of your car rather than in the engine bay?
Its about exhaust scavenging. At a certain length and diameter, the exhaust pulse will create a sonic negative pressure wave at the valve creating a vacuum. That vacuum helps pull up on piston, clear out the cylinder, and suck fresh air into the cylinder. The exhaust itself still exits in the original location in most situations. On most otto cycle engines exhaust contributes to about 5-15% of the engines theoretical performance potential, on 2 stroke engines it can be as much as 40%.
In my case I picked up 7hp and 6 tq over a DC header with the long tube header I designed.
Old 06-08-2013, 12:53 AM   #1300
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by TOUGEghost View Post
Nice wheels!
Thanks,
They were the closest truck wheel match to the ones on our Yaris.
Old 06-08-2013, 06:31 AM   #1301
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Is that design, by chance, available for the rest of us? I'm sure there's a thread, but I'm really lazy in the morning.
Old 06-08-2013, 07:37 AM   #1302
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
That header is georgeous. Do you have any pictures of inside the collector?
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 06-08-2013, 11:52 AM   #1303
tooter
play every day
tooter's Avatar
Sorry, no. But the runners are as clean and neat on the inside as it they are on the outside. And I agree, it's an excellent example of the exquisite beauty of flow design, and I bought it solely because of its visual appeal.
Note the similarity?
Old 06-08-2013, 09:40 PM   #1304
xnamerxx
0-60 in slow
xnamerxx's Avatar
Nope, spent a bit too much time with it to show off.
Old 06-08-2013, 10:31 PM   #1305
tooter
play every day
tooter's Avatar
Who could forget the freaking awesome sound of your dyno runs, namer?
http://www.youtube.com/watch?v=fpkgkDjwHVg
I thought of your project every time I saw these.
But like you said, they only adjust for attitude, but not for length.
Had you come up with any other ideas to resolve the issue of engine arc travel? You seemed to be so close to a functional product.
Old 06-08-2013, 11:45 PM   #1306
xnamerxx
0-60 in slow
xnamerxx's Avatar
I did, it ended up being a bit of a compromise but a flex joint placed in the right place took care of that problem. So far I have 6+ momths of testing on the car and no failures to speak of(knock on wood).
The main reason I couldn't put it into production because I was never able to find a shop that I could get to mandrel bend the tubes for a reasonable cost. The total cost with labor and mending would have been well into the $1000+ range, so it didn't seem viable as something I could sell.
With all that being said I still don't get tired of the torque it produces, it almost feels like a jeep motor now.
Old 06-09-2013, 11:53 AM   #1307
tooter
play every day
tooter's Avatar
I totally understand. New one-off products are always expensive. Could your header have a bung to accept the stock 02 sensor? And does it end before the stock cat? I'm just curious how much it alters the stock exhaust configuration. Oh, and does it hit anywhere under accel or decel?
Old 06-09-2013, 03:26 PM   #1308
xnamerxx
0-60 in slow
xnamerxx's Avatar
No it doesn't hit anywhere.
I'm not sure how it affects the stock cat configuration because I have a custom midpipe, but If I'm guessing you'd need to remove one and move the other. As for the o2 sensors it accepts both in close to the stock location. I chose to do that rather than move the o2 sensors since I have no way of modifying the timing delay for the o2 signal, the downside is I only read half the cylinders.
Old 06-10-2013, 11:15 AM   #1309
tooter
play every day
tooter's Avatar
Sounds like you worked out all the bugs and have a good product with the only obstacle being prohibitive material costs. Maybe in the future something will happen to change that.
Old 06-12-2013, 02:48 AM   #1310
tooter
play every day
tooter's Avatar
I wouldn't be too concerned about that, namer.
I just noticed these Doug Thorley headers that are really popular with the Tacoma 4.0 guys only sample one third of the cylinders!
Old 06-23-2013, 03:04 AM   #1311
tooter
play every day
tooter's Avatar
The tooter et is taking shape...
The hole is still a couple of millimeters smaller than the bellmouth so I'll Dremel it for a nice snug fit ready to weld.
This is going to be an effing strange manifold...
Greg
Old 06-23-2013, 08:12 AM   #1312
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
What does the boob look like on the inside with the flange fitted?
Old 06-23-2013, 11:57 AM   #1313
tooter
play every day
tooter's Avatar
It's really close, but bellmouth doesn't quite fit in all the way. I purposefully drilled the hole small as the hole saw does a considerable bit of wandering. This gives me the opportunity to precisely trim the hole for a good fit. I'll post a pic of the inside when I'm done with grinding the opening.
Old 06-23-2013, 11:25 PM   #1314
tooter
play every day
tooter's Avatar
After a couple of hours grinding filing and sanding the bellmouth has a nice snug fit...
The runners remain in direct alignment with the axis of the throttle body bore...
This is the inside of the plenum, there is a complete lack of any flat reflective surfaces. I'll find out what happens then the pulses travel out the mouths of the runners and hit only curved surfaces.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
