Old 07-17-2013, 12:06 PM   #1
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Starter sticking or ???
Lately it seems like my starter stays engaged longer.. almost too long.
Seems like it is staying engaged even after the motor turns over..
I have found out the key does not control the amount of time the starter turns.. so I cant tell if the motor really is started before cranking stops or not
Sticking starter?? ECM telling to crank too long??
Anybody ever have anything like this?
CueBall is offline   Reply With Quote
Old 07-17-2013, 01:37 PM   #2
Geoff Peace
Drives: Yaris 1.33 litre 2011
Originally Posted by CueBall View Post
Lately it seems like my starter stays engauged longer.. almost too long.
Seems like it is staying engauged even after the motor turns over..
The engine should wind the starter pinion back. If the armature is bent or the pinion is sticking it will cause the problem you describe. Only way to find out is to remove the starter and check for the above.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 07-17-2013, 02:28 PM   #3
CueBall
So the force of the engine is what determines when the starter disengages?
Cuz that's exactly what it sounds like.. like the engine is forcing the starter gear out of the flywheel. But it didnt do this before.. I thought there was something else controling disengage.. like crank/RPM sensor
What if the engine doesnt start? Perma-crank?
Old 09-07-2014, 01:30 AM   #4
whtgsr
Drives: 2006 Toyota Vitz RS
Sorry to bump an old post back up..but im having the same issues with my ncp91. Did you manage to get the problem sorted?? Any ideas on possible issue?
whtgsr is offline   Reply With Quote
Old 09-07-2014, 01:52 AM   #5
whtgsr
Seemed to have worked it out!! Went to this post: http://www.yarisworld.com/forums/showthread.php?t=40811
Have tried starting car this "new" way and it seems to have worked!!! Stoked. Thought my starter motor needed a overhaul..
Starting issue birdman DIY / Maintenance / Service 10 11-28-2018 05:25 PM
Starter Kill david.gartee1 DIY / Maintenance / Service 7 03-01-2014 07:14 AM
Remote Starter - Tail Light Problem Chrsto4 General Yaris / Vitz Discussion 4 10-31-2009 11:36 PM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
Starter dragging YarisTom73 DIY / Maintenance / Service 5 08-27-2007 12:11 PM
