Old 07-24-2013, 07:40 PM   #1
yarista
Drives: 07 Yaris 3dr, 09 Yaris 4dr
Thermostat Question
Does anyone know for sure whether the thermostat in my 07 Yaris will stick open or stick closed in the event that it fails?
yarista is offline   Reply With Quote
Old 07-24-2013, 09:14 PM   #2
It really can fail either way, but I think it would more likely stick closed.
Old 11-28-2013, 01:16 PM   #3
vostorga
Drives: Yaris 2007 Sedan
In my own experience and as ctscott said, when the thermostat of my Yaris failed, it was closed.
vostorga is offline   Reply With Quote
Old 11-28-2013, 01:53 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
If your car takes longer than usual to warm up in the winter.. it's likely sticking open.
Old 11-29-2013, 11:24 AM   #5
esse10
Drives: 2009 yaris 2 door
stick open
In my past experience when folks mix the wrong coolant in the system it corrodes/rust the thermostat and it fails open, or actually there is gunk keeping it slightly open and makes the car's coolant system run colder than normal.
only use the coolant specified for your car and only mix distilled water to avoid problems.
esse10 is offline   Reply With Quote
Old 11-30-2013, 01:58 PM   #6
Geoff Peace
Drives: Yaris 1.33 litre 2011
As said it can stick open or closed. If it sticks closed there is no coolant circulation and the engine will soon overheat. In this instance, put the heater full on and the heater blower full speed to take some heat out of the engine. This may well save the head gasket. If it sticks open, then the engine will run cool and the heater will have poor performance. This is less serious in terms of damage but needs attention, i.e. the thermostat needs replacing as the engine will be inefficient and emissions will be high as a result. I hope this makes things a little clearer.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Need advise (Radiator Hose/ Thermostat Gasket) vellano DIY / Maintenance / Service 7 12-12-2012 11:37 PM
Question about bi amping front components. YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 6 08-28-2010 12:04 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
