Old 07-20-2012, 05:40 PM   #109
harda toenail
Drives: Want a yaris
My new to me 08 hatch 5speed is doing this squeak into 2nd and third. Glad to know its an easy fix!
harda toenail is offline   Reply With Quote
Old 07-30-2012, 07:53 PM   #110
hjsya
Drives: 07 Hatch
Originally Posted by kou View Post
lube this part. if you look under the hood at your linkage move this part side to side and lube. white lithium grease in the spray can works great.
Many thanks. Searched online for a cure, found this post and joined the forum. Lubed the linkage joint with dri slide (motorcycle stuff) and the squeak is gone.
hjsya is offline   Reply With Quote
Old 10-05-2012, 10:43 PM   #111
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Bump.
Did this today and I'm glad to say that I'm squeak free!
Old 10-06-2012, 12:07 AM   #112
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Great tip, took me 2 mins. to get done. This should really be a sticky.
You got it, me from 2009!
Old 10-14-2012, 04:58 PM   #113
reggaetonfreak
El Yoe
reggaetonfreak's Avatar
Drives: Yaris Hatchback
So I bumped into this thread today by mistake, and now im gonna go fix my squeak too. Thank you for the info!
Cuban to the bone, sitting in a Yaris, ahi si hay!!...
reggaetonfreak is offline   Reply With Quote
Old 12-10-2012, 09:14 PM   #114
johnbob
johnbob's Avatar
One less squeak in my world! Thanks for the tweak Kou.
johnbob is offline   Reply With Quote
Old 12-12-2012, 04:04 PM   #115
watersoilair
Drives: 08-2DR-MT-LB-Red
My issue has come back as well... Sigh. Only happens in dry weather. Along with the clutch shudder when it's wet out. I will be taking it back to the dealership as well. Actually, I'm going to call the head office in Toronto, Canada. Cheap parts!!!
watersoilair is offline   Reply With Quote
Old 07-04-2013, 10:01 PM   #116
7:34pm
Drives: 07 Yaris
Just did this today and made a video.
http://youtu.be/fHwTTf-pOhY
7:34pm is offline   Reply With Quote
Old 07-24-2013, 02:13 PM   #117
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I noticed a weak chirping sound last Friday, between 1st to 2nd gear, and 2nd to 3rd. Chirp-chirp is what I hear. I've been worried sick over having to take my car in--of course, the factory warranty was over in June. I have just over 23K mileage on mine.
So...is it lithium spray grease or silicone spray? Which is the best? I hope I can find the spot and this fixes it.
DebbyM46227 is offline   Reply With Quote
Old 07-25-2013, 05:32 PM   #118
ckurowic
Drives: 2007 LB
Thumbs up
EPIC. Thanks for this, I'll try it this weekend on my '07.
ckurowic is offline   Reply With Quote
Old 07-25-2013, 05:33 PM   #119
ckurowic
Drives: 2007 LB
I wouldn't be worried. I have 93k on my 07', it hasn't had a single repair in that time. I've changed the oil on time of course, new tires, just replaced the front brake pads. Hell of a reliable car.
Old 07-26-2013, 09:09 AM   #120
ckurowic
Drives: 2007 LB
Just lubed up the linkage yesterday, zero squeak :). Thanks for this thread! Now to solve the squeaking when I release the brake pedal.
Old 07-26-2013, 05:04 PM   #121
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Wish I could acomplish this as well. Already took off the drum and cleaned the drivers side rear brakes and everything. Squeak went away for about 4-5 stops. Now its back in all its glory, heh.
I gave up.
Old 07-29-2013, 09:40 PM   #122
DebbyM46227
White lithium grease spray was only $2.47 a can at Walmart. 30 seconds of my time and my squeak is gone! :) Kind of awkward due to the radiator hose being in the way.
Old 08-16-2013, 05:22 PM   #123
bryanhoule
Drives: 2007 Toyota Yaris MT LB 2-door
I had the same squeak. I'm at about 83,000 miles. If you like instant gratification, this is a good one! WOW! Problem fixed the INSTANT i sprayed the part highlighted with the yellow circle and two yellow dots. WAY smoother shifting now, way less friction!. Huge difference (and I just changed my manual transmission oil to the Redline MT-90 stuff, and that helped slightly but was nothing compared to lubing these shifting linkages). I used Johnsen's Multi-Purpose Silicone Lubricant. Time will tell how long it lasts. If it lasts a long time, good, if not, next time I'm going to use a White Lithium Grease Spray. I removed the intake air filter box to make the access easier, but it's not completely necessary. Also, while my friend moved the stick through the gears, I sprayed all the moving parts, not just the "yellow circle with two dots" part. Thanks guys! This is a great forum!
bryanhoule is offline   Reply With Quote
Old 08-16-2013, 08:26 PM   #124
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I sprayed lithium grease on the linkage with great result the squeak disappeared.
But is it a sign that there's something wrong with the linkage? Like it needs to be replaced? because it's worn or something etc.
My Yari is going great i'm happy to report it's an 07, 3-door hatch, 1.5 ltr engine.It's done 155 556 km and it's still going and keeps going. Touch wood!
I sprayed the linkage added red line mt 90 along with nulon gearbox treatment. I changed the plugs, air filter, oil filter and of course did regular engine oil changes using full synthetic.
Had wheel alignment and it's going well. I feel a bit of an improvement to the way it's running. Touch wood hoping it continues.
Next in line is front brake pad change :)
Old 08-21-2013, 04:11 PM   #125
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
Fixed my squeek with this as well.. first tried the silicone spray.. lasted about 2 weeks.. came back with lithium grease the second time.. been squeek free for a couple months now. :)
CueBall is offline   Reply With Quote
Old 08-21-2013, 10:07 PM   #126
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Yeah I was also using silicone for this, but it turns out that stuff only works while its viscosity is just right... After that it ends up making things worse, according to the mechanic.
Urgent! How to use auto transmission? hans_fh General Yaris / Vitz Discussion 55 04-16-2010 01:45 PM
2009 Yaris "S" - no 5MT Hatchback? Latka New YARIS Purchase Forum 21 11-07-2008 04:16 PM
New transmission at 8.5K miles! d2dailly DIY / Maintenance / Service 17 09-22-2007 11:41 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Synthetic oil for transmission mrrock DIY / Maintenance / Service 7 04-26-2007 03:51 PM
