Old 07-29-2013, 09:17 PM   #1
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Small noise form drivers side.. :(
Hi guys iv begun getting this small pop coming from the drivers side front end..
Its mainly when i hit a squarish bump, and or turn towards the right..
I brought it to get checked at an alignement place and they told me everything is fine, they checked everything in the front direction.
Can it be the top plate on the strut ?? How do you check that ?? The car has 27000 kms.. thats like 18000 miles.. its practically brand new. We have been getting extremely hot weather here.. do you think its the heat ? Can i apply some lube like silicone lube around all the joints ?? Its not dangerous im sure but it is annoying..
Thanks !!
yaris1F8 is offline   Reply With Quote
Old 07-29-2013, 09:37 PM   #2
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
Maybe the lower control arm bolts? I think there's a recall on that. Mine made a similar noise and that's what it was.
DebbyM46227 is offline   Reply With Quote
Old 07-29-2013, 09:51 PM   #3
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
if you drive on roads that tend to have salt put down to counter act the snow and ice then you may have a control are bolt starting to corrode off, it will look normal until the head of the bolt finally breaks off.
Old 07-29-2013, 11:21 PM   #4
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
It does sound like the noise is coming from the lower end though.. when i brought it the alignment shop the guys tighten all the bolts with an air gun.. do you think they missed those ones.. ??
Old 07-30-2013, 12:08 AM   #5
If they hit them with the impact wrench and they were corroded, one or more may have snapped.
Old 07-30-2013, 04:25 PM   #6
esse10
Drives: 2009 yaris 2 door
x2
x2 That sounds about right all those suspension bolts have specific torque values and some are stretch/torqued bolts. You never tighten those with an air gun.
esse10 is offline   Reply With Quote
Old 08-02-2013, 06:12 PM   #7
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Ok i just got the whole front end checked again, 191 motorsports..
everything is perfect..
I noticed though when i drive my car in the rain... i dont hear it anymore..
Old 10-28-2013, 11:21 PM   #8
geniusmusicman
The Quiet Guy
Drives: 2008 Toyota Yaris 4-Door 1.5L
I know it's been a few months, but did you ever figure out the problem? I am having the same problem now. I have this weird noise coming from the front drivers side and am also hearing it from the passenger side. I hear the noise when I go over speed bumps and dips as well.
geniusmusicman is offline   Reply With Quote
DIY: Adding LED turn arrows to side mirrors my2sense DIY / Maintenance / Service 10 05-28-2012 02:16 AM
Drivers side glovebox door. 07stlYaris Willing to Buy by private party 0 05-03-2012 05:46 PM
how do I replace the drivers side rear view mirror ath DIY / Maintenance / Service 5 04-19-2012 11:47 PM
Loud vibration/rattling on driver's side? Ashley87 General Yaris / Vitz Discussion 3 05-30-2010 02:24 AM
Clicking noise when jerking steering wheel side to side/hit bumps left side eii DIY / Maintenance / Service 8 03-22-2010 06:46 PM
