#1 |
Drives: 2007 Toyota Yaris Join Date: Aug 2011
how do I replace the drivers side rear view mirror
I just got broke my mirror off and got the replacement part, but I have no idea how to install it. Do I have to take the door panel off? Help!
The door panel has to come off to get at the nuts that hold it to the door.
#3 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
#4 |
Drives: 2007 toyota yaris Join Date: Apr 2012
ok guys, where's the great advice? I also need to replace my 07 Yaris drivers side mirror... let's have some realistic how to!
#5 |
![]() ![]() ![]() Drives: '10 Yaris LB Polar White Join Date: Oct 2010
I saw some on ebay...........not OEM but will help your cause.
#6 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
There are screws in the door panel. Likely one where the door handle is, and potentially one more at least in where you "pull" the door from. After you're 100% sure the screws are all you, start pulling at and edge to pop the clips out. When you've got it mostly loose, you may have the unhook the rod that connects the door handle to the door lock. In fact, do this before doing the clips. My bad.
After that, just keep popping clips out and lift the door panel upwards and away from the door. Voila. |
| Loud vibration/rattling on driver's side? | Ashley87 | General Yaris / Vitz Discussion | 3 | 05-30-2010 02:24 AM |
| Side mirror compatibility question | kw531 | DIY / Maintenance / Service | 3 | 12-11-2009 10:09 AM |
| Replacing driver side mirror? | supernes550 | Cosmetic Modifications (Exterior/Interior) | 4 | 01-26-2009 11:11 AM |
