Old 08-21-2013, 11:50 PM   #1387
japle
japle's Avatar
Drives: Vitz S 2007 LB
This should be interesting....
japle is offline   Reply With Quote
Old 08-22-2013, 03:03 AM   #1388
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
It should be. The Prius engine operates within different parameters than the Yaris engine does.
Old 08-23-2013, 04:34 AM   #1389
YotaYaris
YotaYaris's Avatar
Drives: 09 3dr (sold), 12 SE 5spd : )
That bone stock dyno chart is not your car, correct?
I would also like to know about this.
Different Dyno?
Different Day(Humidity/Temp)?
Different Car?
Different Altitude?
Post 1375 is at HK MotorSports in CA
Post 1378 is at Keith's Pit Stop in PA
Its all about the MPG's !!
YotaYaris is offline   Reply With Quote
Old 08-23-2013, 11:52 AM   #1390
tooter
play every day
tooter's Avatar
Different Dyno?
Different Car?
Different Altitude?
I picked the other dyno run because it had higher results than this one, but since you asked, here's a stock dyno run from the same shop and the same dyno machine.
With the stock engine making 106 at the output shaft, 15 horsepower in drive train losses seems to be the norm.
I believe that the first two charts are of auto transmissions, so manual transmissions would naturally have less drivetrain losses. So you can spot them a few more horsepower if they were manuals.
Interestingly enough, we had the same issue with information dropping out on the graphs, but resolved it by grounding the chassis to a bolt in the concrete floor.
Here's another with intake and exhaust mods for comparison.
These are all posted in the dyno thread sticky in this section. It's an interesting read.
Old 08-25-2013, 11:37 PM   #1391
tooter
play every day
tooter's Avatar
Another tooter rolled off the assembly line...
It's available on ebay for $545 with free shipping.
The tooter Build Your Own Intake Manifold Kits are also available on ebay for $295 with free shipping...
Old 08-26-2013, 03:13 AM   #1392
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Originally Posted by mario98c View Post
The stock rev limiter is 6,500rpm.
I would like to know how you have come to this conclusion? I wouldn't go totally off the tach that you are showing if that is your evidence. I have had several dyno runs and the software logging without a shadow of a doubt that 6250 is indeed where the stock ECU begins to force the AFR into a serious lean condition which is how Toyota actually "rev" limits as opposed to other methods.
Old 08-26-2013, 03:16 AM   #1393
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I don't know what post that's from but on my Echo it is indeed 6500rpm. It's different between models.
Old 08-26-2013, 03:39 AM   #1394
fnkngrv
fnkngrv's Avatar
http://www.yarisworld.com/forums/sho...postcount=1382
Old 08-26-2013, 03:42 AM   #1395
fnkngrv
fnkngrv's Avatar
Question What are the real benefits at this point?
So after close to 1400 posts I guess my question is what does this intake actually gain someone? if HP/TQ are negligible are we talking an FE gain at this point? I apologize, but with this many posts even digging back on a couple hundred can be muddled.
Old 08-26-2013, 03:46 AM   #1396
Bluevitz-rs
The PR spec cars might be. The PR spec '03 HB I drove a long time ago had a 6700 redline.
Old 08-26-2013, 03:56 AM   #1397
fnkngrv
fnkngrv's Avatar
^ very good and valid point! I had forgotten that.
Old 08-26-2013, 12:36 PM   #1398
I'll test and video JR's car today. We should be able to hear the fuel cut at 6250... or 6500.. or 6700...
Old 08-26-2013, 12:50 PM   #1399
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
I'm pretty sure the rev limit is 6250, That's the only number that's ever corresponded with my data. 60 MPH in 2nd gear is all I've ever seen with my race tires.
Old 08-26-2013, 12:51 PM   #1400
lol, sorry guys, couldn't resist with the talk about the redline. hahahaha
Old 08-26-2013, 01:06 PM   #1401
tooter
play every day
tooter's Avatar
Just these modest gains and about 2mpg. That's it. It's not a miracle product, just an intake manifold that allows running a larger throttle body. It's primary advantage is excellent throttle response and some improved fuel economy without ruining the reliability of the engine.
If you want lots of power you need to buy a forced induction system. Keep your eyes open for a used one. A lot of them end up being resold.
red: stock manifold with 46mm throttle body
blue: tooter manifold with 46mm throttle body
green: tooter manifold with 55mm throttle body
No problem.
You have your complete answer in just this one post.
Greg
Old 08-26-2013, 01:12 PM   #1402
tooter
play every day
tooter's Avatar
The stock rev limiter on my 2012 cuts off at 6,600.
Old 08-26-2013, 02:25 PM   #1403
If I were still modding my sedan, I'd probably go with the Tooter and the 1ZZ TB based on the torque curve in that dyno graph (I do most of my driving from 2k-3.5k).
Old 08-26-2013, 02:27 PM   #1404
doesn't that dyno show it making whatever power it makes at 3500 and up?
green line?
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
