Old 08-26-2013, 06:30 PM   #91
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Do you have pics of the manifold? Is it log style or tubular?
The Spectacle is offline   Reply With Quote
Old 08-26-2013, 06:57 PM   #92
I think he runs the Ptuning mani
Old 08-26-2013, 09:41 PM   #93
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Hayabusa style tubular, one bend each runner.
File Type: jpg scion-xA-xB-Toyota-1nz-fe-turbo-manifold.jpg (36.8 KB, 201 views)
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 09-17-2013, 05:43 PM   #94
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Tomorrow, the xA gets pushed to the limits, the fueling and clutch holding capability along with the turbo will be maxed out. C16 this time around, with strait h2o injection. Should make for an interesting evening on the dyno.
Ptuning.com
Old 09-17-2013, 06:06 PM   #95
^ OOH. YES. can't wait
Old 09-17-2013, 09:27 PM   #96
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
+100000000000000
Old 09-18-2013, 09:51 PM   #97
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
halfway through the tune, the pulls were becoming inconsistent and the boost wasnt inreasing. The turbo took a crap. On a good note, before the turbo gave it was odvious that the stiffer valvesprings helped a lot. The car was producing power all the way to 8000rpm :)
Ptuning.com
Old 09-18-2013, 09:53 PM   #98
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
So what's next? A new snail?
Old 09-19-2013, 01:51 AM   #99
Sweet. Motor is sound, that's good.
Old 09-19-2013, 07:51 AM   #100
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
yes, most likely a gt3076 . I believe my car eats turbos because of the high boost I run. Also, I may get a high flowing blow off valve such as a turbosmart race port. I think perhaps the turbo encounters surge when I shift. While Im at it, Im going to verify the oil supply and measure the cc per minute.
Ptuning.com
Old 09-19-2013, 07:53 AM   #101
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
oh yea, the valvesprings and retainers are Supertech..... meant for a Scion tC. worked great.
Ptuning.com
Old 09-19-2013, 09:15 AM   #102
Bluevitz-rs
I'm amazed that all the valve springs between all these motors are the same size
Old 09-19-2013, 11:28 AM   #103
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
omg you are my boost role model. I think this was mentioned in another thread, I know you were running a stock motor except the rods. Is the valve springs the only thing you changed or did you upgrade the pistons also this round?
-Derrick-
Old 09-19-2013, 11:56 AM   #104
Toy_Yoda
Drives: 2006 Scion xb
I imagine he had no choice but to get new pistons. He showed photos of the damage in his other thread titled "Finally, my motor went". Number 4 piston was damaged previously from a destroyed spark plug, and number 3 took some serious pounding when the valve dropped. Just wondering what piston set he went with and if there was any damage to number 3 rod.
Last edited by Toy_Yoda; 09-19-2013 at 12:30 PM. Reason: original post sounded like it was in wrong tense.
Toy_Yoda is offline   Reply With Quote
Old 09-19-2013, 01:36 PM   #105
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Same bottom end, pistons and all. Just a replacement head decked and supertech valve springs. I was amazed that the motor pulls 20inhg vacumm after seeing my clyinder walls scored.
Ptuning.com
Old 09-19-2013, 02:03 PM   #106
Toy_Yoda
Amazing! Any additional support to the main bearings? Curious to know who's rods your running and if the crank is stock.
Old 09-19-2013, 05:59 PM   #107
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
no main bearings support other than stock main bearing caps. Crower rods, CP pistons, Supertech valvesprings are only internal upgrades. Stock headbolts, stock intake manifold, stock throttle body.
My build focuses on trying to achieve good numbers and reliability without spending tons of $. xbgod boasts about his $40k motor build, and is producing the same numbers without spray. 90% effect with 10% of the effort (and $) is what I aim for. Don't get me wrong, I use all good parts. Haltec and return fuel sytem are running the show.
Ptuning.com
Old 09-19-2013, 06:33 PM   #108
^ Amen. I run stock crank/bearings/cams/valves as well.
