Old 04-05-2007, 08:00 AM   #19
razzorjet2
razzorjet2's Avatar
Synthetic Oil
Mobil SAE 5W-30 Full Synthetic is the way to go. A little over 4 bucks at Walmart. I'd buy the OEM Toyota filters on Ebay - 40 bucks for a case of 10. At 4 bucks a filter, thats half the cost of the dealer.
the razzor man
razzorjet2 is offline   Reply With Quote
Old 04-05-2007, 09:36 AM   #20
LoudYar
LoudYar's Avatar
Drives: 2007 Toyota Yaris
Originally Posted by Pavel Olavich View Post
MAKE ME AMSOIL BOY! Why don't YOU take your AMSOIL and stick it!
Again, your off-topic. Like YOU told everybody, "stay on topic".
People these day, can't even take there own advice.
LoudYar is offline   Reply With Quote
Old 04-05-2007, 03:38 PM   #21
Pavel Olavich
Drives: 2007 Yaris LB
LoudYar, YOU ARE OFF TOPIC! FOLLOW YOUR OWN ADVISE!
Pavel Olavich is offline   Reply With Quote
Old 04-05-2007, 03:39 PM   #22
Pavel Olavich
Originally Posted by Go4th View Post
Why did you post this? Follow your rules from your 1st post please.
The difference is I'M NOT SELLING AMSOIL...I just mentioned it....there is a difference....ponder this, and you too will see...
Old 04-05-2007, 04:39 PM   #23
ChinoCharles
Drives: LB
Old 04-05-2007, 05:37 PM   #24
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
humm where did I say I am selling AMSOil? What exactly am I supposed to ponder when your thoughts are wrong? Please read completely through the posts b4 you make more outlandish comments.
Go4th is offline   Reply With Quote
Old 04-05-2007, 07:33 PM   #25
Black Yaris
der Zeck
Black Yaris's Avatar
FIGHT FIGHT!!!!
Old 07-27-2007, 07:56 AM   #26
r300f28
Drives: 2007 Yaris Sedan
Changed oil on my Yaris at 1000 miles. Used Amsoil SAE 5-30 & Amsoil filter.
r300f28 is offline   Reply With Quote
Old 08-06-2007, 10:06 PM   #27
Soner
Send a message via Yahoo to Soner
How do you guys change your own oils?
Don't you need a machine that pulls your car up, so you can get under the car and change the oil?
I'm very knowladgeable!
Soner is offline   Reply With Quote
Old 08-07-2007, 05:18 AM   #28
CompanyXPaladin
Drives: 08 Yaris 5-speed
The last time I mixed oil weights in a car, it was blowing smoke out the exhaust pipe until I changed it. I also suffered a number of driveability issues. I would advise not mixing weights. I'm sure it's fine for temporary use, but for long term I would use only corresponding weights.
As far as I knew, it was fairly common knowledge that AMSOIL produced performance fluids for cars - most notably their oil. This answers the question posed in the second post. Look at you guys; arguing and flaming over motor oil. Pathetic.
Soner: The machine that pulls your car up is called a lift. Those will usually run you a couple of thousand dollars for a cheap one. You can go ahead and get one if you like; they are very useful. I personally use a set of ramps; you can also use a carjack and jackstands, all readily available at your local auto parts store for significantly cheaper than the lift(under $60 for a good set?). They all accomplish basically the same thing. The service manual describes the steps required to change your own oil. The filter and drain plug look basically the same on every car, so I'm sure most of the helpful knowledgeable individuals posting in this thread don't rely on the manual. Hope this helps.
CompanyXPaladin is offline   Reply With Quote
Old 08-07-2007, 02:05 PM   #29
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
nope just creep underneath get the drain plugs out ' u may need a jack ..of course take the engine filler cap off first then the most important thing is "drain"..then change oil filter.., put plugs back in fill oil 5w-30 for canada. wala!!!!! you should get this done in under ten minutes including clean up.
Old 08-07-2007, 04:05 PM   #30
Soner
companyxpaladin and marcus thank you for your responses.
I like your sarcastic style paladin :) "You can go ahead and get one if you like; they are very useful."
I will look into the autoshops for jackstands b/c I don't want to pay $50 for synthetic oil change everytime. Plus even if I paid $50, I don't even trust mechanics will put expensive synthetic oil anyways... They will probably put cheap oil anyways b/c not many people can tell the difference.
I have no trust for mechanics. I have my own share of experience with them!
Old 08-07-2007, 06:50 PM   #31
marcus
toyota
marcus's Avatar
just make sure you save your receipts and you wont void your warranty if any. atleast thats in canada im not sure what the policy is in the states.
Old 08-15-2007, 12:42 AM   #32
seanele
seanele's Avatar
Drives: '07 Blazing Blue LB, '09 Jetta
lol
your funny.. shut up!
Originally Posted by AaronATL View Post
thanks for answering the original post, now shut up
you shut up!!!...
(i want to be shut up by somebody else too...anyone??)
current: '07 Yaris LB - '09 VW Jetta
ex: '06 Beetle S(19x8.5 Audi A8) - MK4 GLi BMP(18x8 OZ, K04) - '03 GTi(17x7.5 Ronal, APR93) - '01 GLS - '88 GTi - '86 GTi - '83 GTi
seanele is offline   Reply With Quote
Old 08-15-2007, 12:44 AM   #33
seanele
seanele's Avatar
Old 08-15-2007, 01:00 AM   #34
seanele
seanele's Avatar
2 hours with the Yaris.... ,
you see,
jack the car..15 minutes.
sorry..i have a very high-tech hydrolic jack, or in other words, IT JUST WON"T GO UP EASILY!!!(leaking fluid)
then,
unscrewing the oil drain plug and the oil filter, 30 minutes.
(warm oil sprayed on your face and have the filter fell on your nose..included)
then,
screw in back the plug and new filter, 45minutes. (dinner included, it was at night time)
then,
back to the garage...put new oil and lower the jack. 30 minutes.
(that DAMn Jack WON'T GO DOWN TOO!!.. )
so..there you go!! my best time for oil changing at home...
Old 08-15-2007, 10:50 AM   #35
trini_per4mance
trini_per4mance's Avatar
Drives: 2007 Toyota Yaris S Sedan
As far as oil goes, I've used every brand of 5W-30 syntethic oil out there From Toyota to Mobil1 to Wal-Mart Super Tech. With my car doing 155,000 miles, I've done 30 oil changes @ 5000 miles and each oil change, I use one Toyota oil filter, 3qts of Wal-Mart Super Tech 5W-30 oil and 1qt of oil stabilizer. And my car idles and run as smooth as the first day I bought it.
trini_per4mance is offline   Reply With Quote
Old 08-15-2007, 11:31 AM   #36
Black Yaris
der Zeck
you see,
then,
then,
then,
Damn I changed my engine oil and trans oil in like 20 min.... but I use ramps... screw that jack..... I just stunt driver up on to my ramps, it is always fun with a manual trans
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 09:43 PM
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 09:15 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 03:56 AM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 09:44 PM
