Old 08-04-2012, 12:00 PM   #1
davidags
vitz rs turbo
Drives: toyota vitz rs trd turbo
What's the best emanage for a turbo vitz
Can anyone please tell me what's the best emanage for a Toyota vitz rs trd turbo. I plan to modify this car for drag and autocross.
davidags is offline   Reply With Quote
Old 08-04-2012, 01:00 PM   #2
what's your budget? horsepower goals?
Old 08-10-2012, 12:12 PM   #3
davidags
vitz rs turbo
Wanna go over 250hp? What are my choices sir. An emanage that a novice can understand.
Old 08-10-2012, 02:29 PM   #4
Over 250? I wouldn't trust an eManage, personally. AEM EMS2.
Old 08-10-2012, 02:50 PM   #5
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
But a novice cannot so ems2 ahahha
Interior:ALL red, black roof
Old 08-10-2012, 03:07 PM   #6
Sorry, you can't make big power both reliable AND cheap
Old 08-10-2012, 04:36 PM   #7
packetrace
packetrace's Avatar
Was just kidding :p I already know that Garm! But with your price its nearly
Possible :D
Old 08-11-2012, 12:06 AM   #8
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Does anyone know for sure if the internals of the factory turboded 1NZ are different? Otherwise 250hp will probably leave you with a pile of aluminum bits.
Old 08-11-2012, 01:03 AM   #9
I am pretty sure it's the same rods and pistons. Does anyone know the "stock" boost on the factory turbo? it's gotta be 5 psi or less -- just a guess.
Old 08-11-2012, 09:25 AM   #10
thefalls
Drives: Axio GT
Stock boost is 0.5bar. Confirmed.
I wonder whats wrong with emanage [ ultimate of course] and 250 bhp.
The mighty 4efte pushes around 250bhp with a bolted td04 and that also on stock block. And people have been running above 300bhp reliably on forged blocks. :P
thefalls is offline   Reply With Quote
Old 08-11-2012, 10:52 AM   #11
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
well, the 4efte was built with stronger rods and only produced 30 more hp than the nonturbo 4efe. reguardless. The 1nz weakest point (according to threads) are the rods and seems like can only hold up to around 180-200whp. And if what Cali yaris said is true that they hold the same rods, then trying to squeeze 250whp is really pushing a stock 1nz.
You can not compare the 4efte to a 1nz as far as running the same amount of hp with totally 2 different internal setups
-Derrick-
Old 08-11-2012, 01:45 PM   #12
^ I've spoken with the OP, and he wants 250+ whp -- actually he wants to make what I'm making, over 350 whp, according to his PM's and emails.
His 1NZ is not going to make 250 (for long) without a build.
The OP intends to track the car, so to my mind, management should be the best possible and most robust and reliable unit he can get, especially if he has future plans to make big power.
Old 08-11-2012, 04:50 PM   #13
packetrace
packetrace's Avatar
most people starting at 140whp boost;.. later will go to 200 lolll :D
Old 08-11-2012, 05:44 PM   #14
ilikerice
ilikerice's Avatar
Agreed. but what I was not agreeing with is 'thefalls' post,
basically saying "4efte pushes 250hp with only upgraded turbo, why cant a 1nz do the same.. " no way you can compare these 2 engines.
-Derrick-
Old 08-11-2012, 06:23 PM   #15
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
+1
EMS2 and it will give you unless mistaken possibly the most customization in the industry. You won't make stable reliable power like that on a piggyback. Maybe someone will prove me wrong, but I wouldn't stake the type of cash required to get to 250bhp and go with a piggyback.
Old 08-12-2012, 03:51 PM   #16
250 whp just to be clear. Just repeating the OP's goal.
Old 08-12-2012, 04:32 PM   #17
thefalls
Drives: Axio GT
My apologies for half a post and some confusion. I did not mean that a stock 1NZ can push 250hp reliably with emanage ultimate. The stock rods are weak for this amount of power. And the 4efte was built with turbo in mind.Hence the stronger rods and low compression [8.2:1].So cant really compare these two engines with upgraded turbos and same management.
But a built 1NZ can push 250hp with emanage.
Old 09-16-2013, 10:23 AM   #18
davidags
vitz rs turbo
hi guys, been busy lately. this is what i have done to the car so far, changed the hood, fenders, trunk, doors front and rear bumpers to fiberglass. changed all the glass to plexi. took out everything inside the car and placed a fiberglass seat, coilovers. put in a stage 3 clutch, aluminum pully, aluminum flywheel. plans in the future are water injection, low comp pistons, forged connecting rod, matched porting, cams, front mounted inter cooler. so far i joined an autocross competition and won 2 first place and 1 third place. so which one is better aem or ultimate?. any suggestions to make the car more competitive whould be appreciated .
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
2010 Vitz RS Modellista Completed Car Vitz Rs Modellista Photo-Video-Media Gallery 38 11-18-2014 01:25 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-10-2012 12:35 AM
Help! Turbo my Vitz! Dominican Vitz Forced Induction Forum 7 09-27-2009 11:45 PM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 09:45 PM
