Old 09-18-2009, 10:46 PM   #1
Dominican Vitz
Drives: Toyota Vitz 2002 SR
Help! Turbo my Vitz!
Im planing on making my vitz turbo, but i really dont want much modifications i have read that if you run 7-8 psi you dont need lot of modification, by now i see you will need:
TC Injectors
Piping
Turbo
Manifold
Oild and Water line
anything else?
Dominican Vitz is offline   Reply With Quote
Old 09-18-2009, 11:30 PM   #2
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
do research... not trying to put you down. It is very complicated and at the same time not that complicated. Look at all different kinds of forums on turbo builds and you'll get an idea of what mods you will need. I would suggest a 1.5 differential, a clutch, tach, oil pressure, water temp, wide band air/fuel, boost gauge & controller.
RacerFreakXXX is offline   Reply With Quote
Old 09-19-2009, 12:55 AM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
DPL Vitz, please PM me, i have a few parts that will get you on your way.
Old 09-19-2009, 11:31 PM   #4
puetato89
Just call me Ray, better?
puetato89's Avatar
Drives: 08 Yaris
listen 2 tamago if any one else!!
Old 09-25-2009, 04:42 PM   #5
etheliters
etheliters's Avatar
Drives: 07 yaris hatch
So a stock clutch would be toast with 6lbs huh?
etheliters is offline   Reply With Quote
Old 09-25-2009, 11:02 PM   #6
puetato89
puetato89's Avatar
Drives: 08 Yaris
it would wear out quicker, but not 2 fast, unless you launch it every where im sure
Old 09-26-2009, 01:14 AM   #7
RacerFreakXXX
JDM Fred
IMO spending the $300-400 for a stage 1 or 2 clutch is well worth it. In modding a car it's best to have steppingstones. First you can build minor breather mods (intake, exhaust), then suspension (coilovers, sway &strut bars), then power-train (pullies, flywheel, clutch, diff), then finally forced induction. I would honestly rather have a yaris with pullies, exhaust, intake,coilovers, sway bars, diff, clutch, and flywheel than a turbo yaris with none of that.
Again I point back to my friend who has a 260whp @ 8psi on a 05 civic hatch with just strut bars. NO diff, suspension, clutch, ect. He can only push the car while moving otherwise he wont grip and will sit in place destroying 1 tire.
Remember a 05 civic hatch has about 125whp... so that's basically double whp. It's the same amount you would get with 8 psi on a yaris (80whp to 160whp)
Old 09-27-2009, 10:45 PM   #8
etheliters
etheliters's Avatar
No one mentioned the computer in the car. Will it be ok for him? How much you gonna try to boost Dpl Vitz?
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
TRD Turbo Vitz 田中秀樹 Forced Induction Forum 26 09-26-2007 03:07 PM
Vitz RS Turbo or new Fit RS? Hyde General Yaris / Vitz Discussion 29 09-10-2007 09:26 AM
turbo vitz... ri_espinosa Central and South America 6 07-24-2007 12:11 AM
Vitz Rs turbo vs U.S. Yaris add turbo? weaponrcamry Performance Modifications 18 08-09-2006 08:45 PM
