Old 11-13-2013, 12:58 PM   #19
Black_griffin6
Black_griffin6's Avatar
Drives: 09 Meteoric Metallic 3 door HB
So there's no negative connection? I always thought you had to have positive and negative.
How do I tilt the cutoff?
I'm sorry I have so many questions, this is my first projector retrofit/HID experience. XD
Black_griffin6 is offline   Reply With Quote
Old 11-13-2013, 01:34 PM   #20
if you turn the projector in the headlight you should be able to seat it so the cutoff is flat, no?
keep in mind, if you remove the bulb and look through the projector you can see the plate for the high/low beams....you should notice that everything will look upside down...
in past, ive used a flashlight to set the projector angle in the headlight....just sit the headlight on a table flat as it would sit in your car...might require some propping
aim it at a nearby wall and adjust the angle of the projector
Old 11-13-2013, 01:39 PM   #21
Black_griffin6
I did notice everything looked upside down.
I was referring to the 3 pointed clip in the back that comes with the projector, it fits into the OEM housing and when it's seated in there it's at a strange angle.
Would you recommend not using it?
Old 11-13-2013, 02:41 PM   #22
hmm, its been a while since ive done one...i forgot they had that for the H4 seat
if the whole thing is at a 45* angle, something is wrong....
Old 11-14-2013, 08:51 AM   #23
Black_griffin6
I suppose I could just work without it? I don't think it should move.
Old 11-14-2013, 05:00 PM   #24
It shouldn't move once tight...
Old 11-18-2013, 01:32 PM   #25
Black_griffin6
Got them installed. I'll try and get some pics once I get them adjusted.
Sedan HID Projector Retrofit Headlights !yaris! Cosmetic Modifications (Exterior/Interior) 10 10-26-2017 02:31 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Retrofit Question ChinoCharles Cosmetic Modifications (Exterior/Interior) 19 05-13-2009 06:20 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
