Old 05-13-2009, 02:13 AM   #1
ChinoCharles
Drives: LB
Retrofit Question
OK, so I have the headlights installed and working. Brilliant!
Not so brilliant: kills the high beams, which I knew. However the retrofit is so damn bright I don't care. Question is can I wire the stalk to a set of fog lights in a way so that turning my high beams on in the cabin actually turns on the fogs?
Old 05-13-2009, 05:29 AM   #2
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
most likely all you gotta do is find the high beam wires and run them to the power side of the fogs and disconnect them from the headligh bulb harness so they dont turn those on
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-13-2009, 06:09 AM   #3
+1
Problem is, doing it this way, it would be like the regular lights, once you turn on the high beams?fogs, the low beams will be disabled, and it's not such a good idea for HIDs to be turned on and off quickly like that...
I do think there was a similar discussion in the past though, about the ability to have both high and low beams on at once. Might have been lost in the hack but I'll dig around...
Old 05-13-2009, 12:30 PM   #4
ChinoCharles
Drives: LB
Bump
Old 05-13-2009, 02:21 PM   #5
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
picture of new lights
Old 05-13-2009, 02:31 PM   #6
ChinoCharles
Drives: LB
Violin built them. He did a phenomenal job.
Old 05-13-2009, 02:40 PM   #7
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i like.. does violin sells them?? how much..is it cheaper the micro..
Old 05-13-2009, 02:46 PM   #8
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
those are pretty old. looks good.
Old 05-13-2009, 02:48 PM   #9
taKuto
rice rocket
taKuto's Avatar
Drives: 05 Echo
+1
that's just a matter of diodes and relays. Assuming you have the proper relay harnesses already, you just need diodes. When the low-beam ground shuts off, you want to have the relay signal wires to still use the high-beam ground, and that will keep both on.
taKuto is offline   Reply With Quote
Old 05-13-2009, 02:48 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
OLD? not sure but better looking that DEPO crap.....
Old 05-13-2009, 02:51 PM   #11
PETERPOOP
PETERPOOP's Avatar
if he bought the ones from violin, he made those in the begining of 07. Unless he had violin whip him up some new ones?
Old 05-13-2009, 02:52 PM   #12
ROCKLAND TOYOTA
TRIM HUNTER
and thats old?
Old 05-13-2009, 03:00 PM   #13
ChinoCharles
Drives: LB
Nope, they're the originals.
I ended up buying a harness. I didn't have the cajones to build one myself. I got it from theretrofitsource.com.
Old 05-13-2009, 03:11 PM   #14
ChinoCharles
Drives: LB
By the way, they sat in my closet for over a year. Hopefully that explains everything lol.
Old 05-13-2009, 04:45 PM   #15
WolfWings
WolfWings's Avatar
Looks decent, makes me think more seriously about doing the front-end overhaul on mine. Though I'll admit it's a bit of a pipedream, still want to just yank the whole front clip including the fenders, get a single-piece front shell made and replace the headlight modules with headlights more in the style of a TVR Chimera or the like.
Old 05-13-2009, 04:55 PM   #16
ChinoCharles
Drives: LB
I forget what I paid for these. I think $600 lightly used. They're a jubgundous PITA to make. It was well worth it. They're from a BMW E46 if I'm not mistaken.
Old 05-13-2009, 05:03 PM   #17
PETERPOOP
PETERPOOP's Avatar
$600!? and you make fun of people buying blitz kits!?
garm is bringing in the projector HID bi-xenon kits (not installed in the housing) to be able to do retrofits like camells. going to cost $200. i'll let you know how it goes.
Old 05-13-2009, 05:08 PM   #18
ChinoCharles
Drives: LB
$600!?
Sure... the projectors, ballasts, bulbs, shrouds, labor... this isn't kiddy shtuff.
Mostly you, you sucker.
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 12:38 PM
So question here abt hatchs in general Jem_hadar General Yaris / Vitz Discussion 12 01-06-2009 03:06 AM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 10:27 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 05:44 PM
