Old 01-21-2014, 11:45 AM   #19
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
Originally Posted by d3310n View Post
but i thought yaris springs couldnt be cut because of the shape, they wont seat properly? and ive always heard cut from top only
That's generally true, as the springs do wind tighter (to a smaller circumference/ diameter) at the ends. But that's why I said just 1/4 of a coil off of each end.
You could probably do up to 1/2 of a coil off of each end and still have it seat fine. You would run into other issues then though, like the spring being too short and possibly falling out at full droop.
And there is no general rule that you should only cut from the top or bottom. It's whatever works in the specific application. You just have to thoroughly assess the limits that you have to work within, be smart about it, and only cut a little bit at a time.
D&D is offline   Reply With Quote
Old 01-21-2014, 11:52 AM   #20
d3310n
Drives: black titty
oh ok. work on this yaris may halt, as im selling it and buying a miata/86
d3310n is offline   Reply With Quote
Old 01-21-2014, 11:57 AM   #21
D&D
It's Quacktastic!
D&D's Avatar
oooh, fun!
Old 01-21-2014, 02:43 PM   #22
Not if you ziptie it to the perch
Old 01-21-2014, 02:45 PM   #23
D&D
It's Quacktastic!
D&D's Avatar
Now you're talkin'!
Help! Right side lower control arm removal RUBBERDIPSTICK DIY / Maintenance / Service 15 12-27-2018 01:29 PM
Decision to lower more? Yarflana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 03-14-2013 01:00 AM
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
