Old 01-02-2014, 01:01 PM   #1
d3310n
Drives: black titty
just need to go a bit lower...what do
coilovers are so expensive. i have mi springs and stock shocks. new wheels are 15x7 +20 rollin on 185/55/r15. with my old 17s i had almost no wheel gap and i was expecting more, but i knew itd look like this and i accept it. question is would the blue shocks lower my hight? what about cutting the springs a SMALL amount? i dont want to be supa herra frush just like a quarter to half inch lower.
oh yeah and to all the people who said this offset would rub, i have no idea what youre talking about, ive only rubbed once onder hard conering with a big dip i didnt see.
d3310n is offline   Reply With Quote
Old 01-02-2014, 04:21 PM   #2
rikk
rikk's Avatar
Drives: 2007 Yaris Hatch
i like those wheels
rikk is offline   Reply With Quote
Old 01-02-2014, 05:17 PM   #3
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Dude, this is just my opinion, but you have the perfect amount of gap...
Even all around...
Old 01-02-2014, 06:06 PM   #4
d3310n
Drives: black titty
:D thanks guys, was real nervous about how these wheels would look
Old 01-02-2014, 06:29 PM   #5
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
you know u could go up to a 195/55 15 would fill the gap nice.
nice rims
Old 01-02-2014, 07:12 PM   #6
d3310n
Drives: black titty
I could but I wanted this super mild stretch because I was paranoid about rubbing. And I don't think the yaris looks good with bulge anyway unless its all tracked out
Old 01-02-2014, 07:19 PM   #7
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
true on that ..its ur offset of 20 that is the problem in a way...im planing for this summer to run 195 55 15 on 40 offset rim 6 inch wide. ..im on sportline springs and that set up will really fill the gap...may option for tein s tech to go lower..well im hoping they do over sportline.
Old 01-02-2014, 07:36 PM   #8
d3310n
Drives: black titty
6 inch wheel? you sure you want that, even though my 7.5 wheels rubbed, i kinda do miss the rubber. when you put too wide of a tire on a narrow rim its like driving on bid baloons, youd grip better on a 7 or up
Old 01-02-2014, 07:38 PM   #9
d3310n
Drives: black titty
but my question still stands. what happens to ride height if i get shorter shocks?
Old 01-02-2014, 07:53 PM   #10
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
shocks ...nothing ...springs yes ... 195 55 15 on 6 inch looks just right had that on my integra was a square look no bubble look and its about same as stock size over all to a 185 60 15 ....that yaris come with lower u go the more aggressive the look and more fun to drive but can be a pain on a daily driver as i found out on my integra..she was just 2 inch off the ground front bumper looked like a cheese grader went over it lol. ...im about 1,7 to 1,8 drop now ...bigger tire will fill the gap but raise the car
Old 01-02-2014, 07:57 PM   #11
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
see u are in florida so if i lived there i would go coilover all the way here i have winter to deal with and coilover just dont stand up to salt :(
Old 01-02-2014, 08:14 PM   #12
d3310n
Drives: black titty
ah i see, yeah florida is nice and flat mostly, but for some reason the area i just moved to a lot of places of buisness have very steep driveways. huge pain to get in and out even on these springs when theres traffic
Old 01-02-2014, 08:41 PM   #13
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
this pic is from this summer with sportline and 14 inch rims with 175 65 14 , they are 23 inch over all by going to a 195 55 15 it will go up to a 23.65 inch so will fill in the gap....
Old 01-14-2014, 10:08 AM   #14
Lars
Yaris beginner
Drives: Yaris XP9F
From my limited mechanical understanding... shocks only change how "quickly" your springs compress/extend, so in a steady state shocks make no difference to ride height.
Getting stiffer shocks will have an impact on travel range (reducing it) because it will allow for less bounce from the springs... but steady state, no difference.
Correct me if I'm wrong please.
Lars is offline   Reply With Quote
Old 01-14-2014, 11:05 AM   #15
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
what part of Florida? It's time to come out and join the FL Yarii crew.
Old 01-14-2014, 11:25 AM   #16
...and that my friend constitutes a rub. If you are 99% of the time the sole occupant of the vehicle, then 99% of the time you will be fine. Start to add a rear passenger or two, or some weight in the hatch, and the back end will start driving you crazy.
Nice wheels BTW
Old 01-15-2014, 04:49 PM   #17
D&D
It's Quacktastic!
D&D's Avatar
Drives: '07 Yaris Hatch
Just cut 1/4 of a coil off of each end (top and bottom) of the front springs, and 1/2-1 coil off the bottom of the rear springs and you should be set for what you're looking for.
Be prepared to rub more though. Then you'll have to start hacking up the splash shields and whatnot up front.
D&D is offline   Reply With Quote
Old 01-20-2014, 10:11 PM   #18
d3310n
Drives: black titty
but i thought yaris springs couldnt be cut because of the shape, they wont seat properly? and ive always heard cut from top only
Help! Right side lower control arm removal RUBBERDIPSTICK DIY / Maintenance / Service 15 12-27-2018 01:29 PM
Decision to lower more? Yarflana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 03-14-2013 01:00 AM
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
