Old 04-05-2014, 11:39 PM   #19
Hershey
The tech that test drove the car with me in it tested for the mounts and said it is fine . Is he right , I . Things are not turning out to well with work performed .
Old 02-27-2015, 09:10 PM   #20
Flammable
Flammable's Avatar
Drives: 2012 Yaris SE
Originally Posted by Hershey View Post
Yes , these are the NGK IFR5A11 installed at the factory .
I have heard these iridium plugs can last 200k miles. :-)
Flammable is offline   Reply With Quote
Old 02-28-2015, 01:19 PM   #21
Jcp123
Drives: '00 Echo
I pulled a set of Iridiums out of my Echo, at 192k they were shot. I'd say 150-175k at best.
Jcp123 is offline   Reply With Quote
Old 02-28-2015, 07:35 PM   #22
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
IIRC, that big gap is normal for plugs with iridium tips.
I have had a look at mine (68k km), and they almost looked the same, just a bit less of coal on them.
However, I suspect american cars to run a bit richer than european ones.
Might be due to different emission standards, I'll have to do some research in order to get clarity.
Btw, how is your long term fuel trim?
I drive, therefore I am.
dj92 is offline   Reply With Quote
Location of Spark Plugs KEVBD DIY / Maintenance / Service 7 02-03-2012 11:05 AM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
