![]() Drives: scion xb Join Date: Nov 2013
GUDE cylinder heads opinion
Im looking for anyone whom has experience with these,it seems quite reasonable outlay of money for a 20-30 h.p advertised increase. Like any performance mod ..better off believing it makes 1/2 of what the seller claims
. But a 20 h.p increase is pretty hefty for these lil engines..and might just pass a smog inspection in Calif.Turbo is totally un-drivable for a daily driver @200 miles a day and the cost is a waste of $ at 6-7 thousand bucks..Id buy a used M3 before I ever consider that. A Supercharger is just too much $ once all the engine management stuff required is added , also could as the turbo could " technically" get my car impounded Anyways Pros and Cons on the GUDE cylinder heads..dual valvesprings, has that caused any maintenance issues? How do you consider their port work and has it made any "real" VERIFIED performance increases...not just a dyno printout we all know that often its usually engineered for sales. Would prefer some side to side comparisions. Thanks in advance |
Only Happy When it Rains
The only one I think who actually had one might have been hellion, not sure he comes here much but he was on microimage selling some stuff off of his car, might be able to ask him there.
Also check out CTScott's thread about the used s/c on ebay going for $1600. That is a deal.
Colin Chapman disciple |
Mr. 155 and climbing
The first real question since you are talking about how expensive certain builds are would be what is your price range for parts and labor. Gude doesn't ha e a very good reputation with the 1nz as far as I know and I ha e been part of the 1nz family for almost 8 years. There is some discussion about making some NA changes that will actually net you a 30-40 wheel hp/tq bump in the Dyno Chart thread recently.
sent from my m-o-b-i-l-e
0-60 in slow
From everything I've seen porting doesn't seem to give much more lift flow. So it probably won't give much HP withought changed to cams and such.
I read an article on one of the Scion sites a while back and it does have the results that they claim, but to reach its full potential you need fuel management, so make sure you factor that into the cost. If I remember correctly the cost about $1800 + your head as a core. Add fuel management and installation to that and you are up in supercharger or turbo range. I would imagine as well that to take full advantage you would also need to upgrade the air intake and exhaust manifold to match the extra flow of the enhanced head.
If you want to add performance without having your California inspection issues, why not swap the engine to a Scion XD 2ZR-FE, which is the 1.8L offered in the Vitz in Japan. It would look stock and the XD ECM can be easily reprogrammed with your VIN, so that the ECM would even respond with the proper VIN.
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| Gude cams "NOT SO NACHO" | xbgod | Performance Modifications | 77 | 01-27-2011 01:45 PM |
| DIY Hood Cylinder | churp | Cosmetic Modifications (Exterior/Interior) | 46 | 06-25-2007 05:46 AM |
| Canada Only - Maybe a $1000 enviro rebate on Yaris> | MDF | New YARIS Purchase Forum | 45 | 05-01-2007 08:17 PM |
