![]() Drives: Toyota yaris Join Date: Jun 2014
Yaris leaking water?
I have a 2008 yaris that's leaking water from the passenger side when I drive it and the air conditioner is on. It's not a clogged pipe and it's not coming from the dashboard. I checked around and the pic is where it's coming from. Thanks for any help!
That is the bottom of the fan motor. If it is leaking from there, then your condensate drain is definitely plugged. The drain hose is right under the top corner of the carpet to the left of there. Pull it out and stick something flexible up it and wiggle it around.
| Tags |
| air conditioner, broken, fix, leak, water |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 06:14 PM |
| My 2012 Yaris review... | CanIHazYarisHatch? | Third Gen Yaris General Discussion | 35 | 02-20-2012 01:03 PM |
| Testing water on 3 Drive Throttle Controller for Yaris (Vitz) | twpanson | Performance Modifications | 57 | 10-31-2009 02:07 AM |
