Old 09-13-2014, 03:07 AM   #1
bairjo
Squeaky Brake peddle
Well I have a squeaky brake peddle when I let up on it. What is interesting as I had the same thing happen when I had my 08 Yaris but did nothing about it. So before I start crawling around down there and spraying WD40 all over everything, has anyone else had this and what worked to get rid of it?
Old 09-13-2014, 08:33 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Rear drum needs cleanup and lube. I have it on mine and it will always come back. :(
Old 09-13-2014, 09:16 AM   #3
fourbangingfun
fourbangingfun's Avatar
+1
Take off the rear drums.. Brakleen everything. Use a flat head screwdriver to pry the shoes away from the backing plate about 1 cm.. Notice 6 hot spots per drum, three per shoe. They can be seen on the backing plate when the shoe is lifted. That's where your noise is probably coming from. Brakleen those. Lube them up with something. I used white lithium grease. Make sure no grease or lube gets on the braking surface! Enjoy your newly quiet brake pedal!
fourbangingfun is offline   Reply With Quote
Old 09-13-2014, 12:21 PM   #4
bairjo
Thank for your responses. However, this sounds like it is coming from inside under the dash at the peddle area. I also get that rear brake squeak your are referring to and that is under control...for now.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 07:05 PM
Front brake caliper pins DarkSkyGhost DIY / Maintenance / Service 7 06-10-2014 09:05 AM
red hot brake shoes tommo DIY / Maintenance / Service 1 08-31-2011 08:34 PM
