Old 04-26-2013, 10:31 PM   #19
jayeh
Drives: '08 Yaris LB
Originally Posted by nookandcrannycar View Post
The 12.777 gallon fill up = when I ran out of gas while pulling up to a pump to get gas. My usual fill up is probably between 12 and 12.5 gallons. I pay ettention to how many miles I'm getting from each bar on the current tank as well as the total miles so far on a current tank when deciding when to fill up.
Most are mine are in the 8-9 gallon range. Makes more sense now.
jayeh is offline   Reply With Quote
Old 04-27-2013, 12:21 AM   #20
nookandcrannycar
Oops. I do know how to spell attention .
Old 04-28-2013, 11:06 AM   #21
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Also note nookandcrannycar fills the tank until he can see the gas.
Colin Chapman disciple
Old 04-28-2013, 03:19 PM   #22
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
What I would like to do is add more capacity to my gas tank. I have often toyed with the idea of getting a 20 gallon tank. You could go a long way or a long time without gassing up.
I wonder how hard it would be to drop the OEM tank and get an aftermarket tank. How would that effect the gas gauge?
Big Dave
Indianapolis, IN
Synthetic Oil....its in my car.....for at least 10,000 miles!
daf62757 is offline   Reply With Quote
Old 11-04-2014, 04:10 PM   #23
rasals
Drives: 2009 Yaris Sedan
Kilometers/tank
Can someone please tell me approximate total KILOMETERS per tank?
I've found that my fuel indicator stays above half a tank until nearly 500 KMs, then suddenly drops to two bars, to be followed by the blinker pretty quickly.
I've been estimating at about 600km/tank to be safe.
What is everyone else getting in kilometers?
Thanks
rasals is offline   Reply With Quote
Old 03-11-2015, 12:17 PM   #24
cavramopoulos
Drives: 2012 yaris hatchback le
Hi All,
has anyone noticed if when they power their car on and the dashboard lights up if the fuel light comes on as well? I noticed all my warning lights came on except that one and want to know if maybe the sensor is burnt out on it.
thanks
cavramopoulos is offline   Reply With Quote
Old 03-11-2015, 12:54 PM   #25
Jcp123
Drives: '00 Echo
Originally Posted by Deathegg View Post
Also keep in mind that some of us have had problems with the fuel gauge not reading correctly, so that it reads as 1/4 full, but you're almost out of gas. Keep track of your miles with the odometer so you don't run out of gas.
I have this problem as well in my Echo. Sucks.
Jcp123 is offline   Reply With Quote
Old 03-11-2015, 01:03 PM   #26
cavramopoulos
have you tried getting it fixed? or were you told this is an echo feature? reason asking is because my gas meter pin I noticed stays in place where my gas level is until I lock the car...this never was the case from 2012-2014, the minute I took my key out the engine the gas meter would reset as expected. Toyota is telling me that I am lieing about this which I am not and do not know how to get it resolved. let me know if you have the same issue
Old 03-11-2015, 01:25 PM   #27
Jcp123
Drives: '00 Echo
Never really attempted to fix it, I inherited this car from my wife... She can't remember when it started doing that.
Old 03-11-2015, 01:29 PM   #28
Jcp123
Drives: '00 Echo
Thanks
I usually get a little above 400 miles / ~650km per tank. This is on 10.5g, I usually fill up with 9-10gal, leaving some extra in there. My ferry range would be higher.
My longest tank was over 500mi (800km), summer before last when I had a fantastic commute. At that time, though I was stuffing the tank right up to the fuel cap, ignorant of the dangers this posed to the canister.
Old 03-11-2015, 01:31 PM   #29
Jcp123
Drives: '00 Echo
I've liked that idea myself. 12-14g would be fine. I have had some crazy ideas such as seeing if I can bang the tank walls out a bit to get some extra volume. Don't know why just because it's an economy car made for good fuel economy, we can't have a bigger tank.
Old 10-28-2018, 07:07 PM   #30
Ajzak
Drives: Toyota Yaris
Help please!!!
I have 09 (06-09) 1.4D Yaris, and when i refuelled it (twice) my bar (square) after short time period went up , but my "available" km did not move? As if I never refueled it? Help
Ajzak is offline   Reply With Quote
fuel gauge
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Help ASAP!!!! low coolant indicator MeggiemobileSFLA DIY / Maintenance / Service 29 08-03-2013 02:09 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 04:34 AM
Low fuel light falkor_99 General Yaris / Vitz Discussion 35 08-24-2007 04:20 PM
Fuel low light issue Kitt DIY / Maintenance / Service 3 03-22-2007 02:44 PM
