![]() Drives: 2010 Yaris Join Date: May 2015
How much the dealer normally charge to replace it?
2 questions in one. haha you sneaky little one. :)
i changed my belt at about 128000km. It was dried and cracked, and at the priced it cost at the parts store, i just changed it myself. I got a goodyear gatorback. |
![]() ![]() Drives: Yaris Join Date: Feb 2013
I changed mine at around 85,000km just for preventive maintenance. It is not expensive at all and changing it at a mechanic will take less than 10min... So obviously labour won't be expensive
OP is asking dealer cost for install. Flat rate or job pricing at North American dealerships. There have been some dealer quotes provided on this site. They are outrageous for what the job actually is. At job pricing, the minimum you'll pay for is 30 minutes. Dealerships running typically in the area of $100/hr, that's at least $50 plus materials.
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
Mine has 135,000 and counting.
Gotta do some preventative maintenance (besides oil and filter) one of these days... |
If I remember correctly the dealer is around $100 give or take. My mechanic changed my Echo's serpentine belt+power steering belt 4 years agowhile he was changing a coil pack and only charged an extra $40.
If you have any sort of basic mechanical ability it is very easy and quick to do yourself. Otherwise go to an independent mechanic. If you do it yourself avoid using the OCV as leverage to tension the alternator. I changed mine at 130,000km since I was already installing an oil catch can. It had the typical small cracks along it but it could have gone at least another 10,000km no problem. I likely won't change mine again until I hit 300,000km checking on it every so often |
I had mine changed at just over 207,000 miles (only time). I bought the belt at a Toyota dealer (same one used when purchasing the control arm bolts), and had the same outside shop install the belt (also under $30).
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2007
I change mine every 100,000 miles, whether it needs it or not. I've changed it twice and never had an issue.
![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Dealer quoted me $ 165.00 for an unsolicited belt change when I was in for recall work and oil change. I said no thanks, but thanks anyway.
When I got home I checked it, a few cracks, ( I think I read or heard somewhere 7 cracks per inch time to change, or perhaps I just dreamt it after having spicy food for dinner) anyway a few cracks, minimum glazing, and no fraying and grooves still deep. 63K miles |
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
serpentine belt
it's always good to change it before it breaks and leaves you stranded. mine looked like it was still in good condition but I changed it myself at around 80k miles, just use a good brand.
![]() ![]() Drives: NCP91 Join Date: Jul 2012
I replaced at 40'000 km, preventively. Engine runs quite often and I drive north often during the harshest winters. Always genuine Toyota made in Japan part. I always service or replace preventively, a policy I've adapted from Japanese culture through a Japanese friend of mine. The only part I've had to replace due to unanticipated wear are my front control arm bushings.
![]() Drives: Toyota Yaris Hatchback 2008 Join Date: Jun 2015
Hi there,
I've been driving my yaris hatchback since 2009 and have driven a little over 204,000 kms. Although the car is working fine, but I've started to feel that the speed acceleration is now getting painfully slow and braking is not as smooth as it used to be. My question is that is it time to sell my vehicle mainly due to the KMS or can I still drive it? My daily commute is about 100KMs+/-. Has anyone driven their hatchback for these many KMs or more? Some people told me that my vehicle (yaris hatchback 2008) doesn't come with a drive belt - there's only a chain that doesn't need to be replaced. Is this true? I've never gotten neither this belt/chain nor the steering wheel stuff replaced. Should I get them replaced? |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
I swapped mine out at 80,000 miles. It had all sorts of little cracks. A cheap bit of insurance to swap it out earlier than later.
Subcompact Culture: The Small car blog |
| Yaris 2 D4D 2009 without AC serpentine belt | rasyaya | DIY / Maintenance / Service | 6 | 07-17-2014 09:02 AM |
| Finally, 450,000 miles on my 07 Yaris in 5 years | trini_per4mance | General Yaris / Vitz Discussion | 36 | 12-07-2011 07:41 AM |
