Old 09-21-2015, 06:40 PM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
Rust on transmission
There is some rust on the top of my transmission. I'm guessing it was caused by the horrible battery corrosion that happened with the previous owner.
How concerned should I be about this? I made sure to wash the area in baking soda and water.
Tip: When buying a used car, always inspect the car thoroughly, and always do it during the day. I didn't discover the broken radio antenna and battery corrosion until days after I bought the car from the dealer.
attrapereves is offline   Reply With Quote
Old 09-21-2015, 07:57 PM   #2
It shouldn't be an issue, as long as the corrosion did not get into the switch assembly that the shift lever moves.
Old 09-22-2015, 07:03 AM   #3
bronsin
bronsin's Avatar
I guess theres no dealer warranty?
Old 09-22-2015, 08:06 AM   #4
attrapereves
I bought the car earlier this year. It came with a short warranty on all repairs.
If I had seen the battery corrosion and the missing antenna, I would have asked for that to be repaired before purchase.
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 10:07 PM
My 2010 yaris is on its 4th transmission!! Help please Uzairlexus DIY / Maintenance / Service 12 07-16-2013 11:46 PM
need experts helo on robotic transmission clutch mariann DIY / Maintenance / Service 0 10-03-2012 01:51 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
