Old 10-22-2015, 05:49 PM   #1
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Brake pedal side to side play
I was wondering if any other 3rd gen owners have side to side play in their brake pedals. My 2014 (auto trans, big pedal) has more side to side play than any other car I've driven. It doesn't affect the pedal application, there is no up and down play before the pedal engages. It's just really more of an annoyance.
I crawled under my dash and was able to get a wrench on the upper bolt where the arm of the pedal is connected but it was plenty tight. I could barely turn it, maybe one flat on the nut. Didn't make any difference. Maybe that's just the way it's designed but I was curious if it's just me or common among the model.
Old 10-22-2015, 10:23 PM   #2
LTHatch
Drives: 2013 Yaris Hatchback L
Yes my 3rd gen also has the side to side play, never noticed it until you mentioned lol. No clue if its normal but 2 years and no issues with braking so i assume its fine.
LTHatch is offline   Reply With Quote
Old 10-25-2015, 03:21 PM   #3
NYC-SE
NYC-SE's Avatar
I would appreciate it if others weighed in, even if the answer is no. Also if any 2nd gen owners have this issue feel free to join the conversation. Trying to get enough replys for statistical significance. Thanks.
Old 10-25-2015, 07:01 PM   #4
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Very little on my brake and clutch when I get down there and tug on them for side-to-side movement - but nothing remotely significant. Seems normal enough to me.
Kalispel is offline   Reply With Quote
Old 11-13-2015, 08:26 PM   #5
YarTed
Drives: 2015 Yaris 5Dr
I finally remembered to check my 2015 Auto. The brake pedal feels tight, I did not measure but at the pedal maybe 3/16 sideways movement.
YarTed is offline   Reply With Quote
Old 11-13-2015, 10:14 PM   #6
NYC-SE
NYC-SE's Avatar
Thank you for your feedback. Like I said it's not really an issue. I was just curious if I was the only one.
Old 11-14-2015, 06:47 PM   #7
YarTed
No problem, for peace of mind its always worth it to ask.
Ted
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
Problem removing front brake rotor jkuchta DIY / Maintenance / Service 24 02-27-2016 09:41 PM
The brake story: frequent disk warpage Lux DIY / Maintenance / Service 20 11-01-2014 12:25 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
