Old 10-23-2015, 11:23 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Transmission Mount Replacement
Anyone have the procedure on changing on an 08 sedan? It has a little bit of play and makes sounds when I shift. Where is a good place to order parts?
xdarkxfirex is offline   Reply With Quote
Old 10-24-2015, 10:47 AM   #2
MUSKOKA800
MUSKOKA800's Avatar
Can't comment on the procedure but can say that A&A Auto on Woodward have friendly service and great prices. I sourced my serpentine belt and brake components there.
Old 10-24-2015, 05:14 PM   #3
xdarkxfirex
I do know a&a off woodward. I live close to their. There customer service is sometimes good, but I'm not a big fan. Reason being, everytime you go in and buy something off the shelves, the price is usually higher when they scan it, and they think you are lying about it. When you call, you will often be on hold till the line disconnects, and two weeks ago, they gave me the wrong wheel cylinder.
I find carquest, or hdap many times has better prices fyi. Not hating, just my experience.
I got my serpentine belt from cheap from amazon, the bando. OEM belt, the dayco I used was garbage. My brake components I bought from primechoiceautoparts, they arent bad. They use bendix pads for their ceramics, and cheaper rotors, but I found their prices better than anywhere around here
Old 10-25-2015, 08:38 AM   #4
tmontague
tmontague's Avatar
Try a quick search on this forum or Google, there was a thread a month ago about the procedure for the tranny mount.
Very simple to do yourself. Remove battery and intake. It's directly below the battery tray. Just get a jack with a block of wood under the tranny so you can support it when you remove the mount. I believe it's either 2 14 or 17mm bolts on the frame and one attached to the tranny.
I would recommend rockauto.com for parts. The other option is parts source. Will be much more pricey but a lot of times you get a lifetime warranty which is great if you plan to run the car for a long time and do your own work.
Post back if you have any issues, I changed all 3 of my motor mounts in my echo last summer.
mounts, toyota, transmission
Manual transmission fluid replacement Kitt DIY / Maintenance / Service 10 10-05-2015 11:19 PM
08 Yaris Auto Sedan. Pass side motor mount replacement question Kdaddy81 General Yaris / Vitz Discussion 4 09-20-2015 12:51 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
wtb transmission mount str8Yaris Willing to Buy by private party 0 06-04-2011 09:59 AM
