Old 09-07-2015, 05:44 PM   #1
Kdaddy81
Drives: 08 yaris sedan
08 Yaris Auto Sedan. Pass side motor mount replacement question
How do I replace this? I tried already braced engine and all. Is there a bolt underneath or something I'm missing? Any and all help much thankful for...
Keith
Kdaddy81 is offline   Reply With Quote
Old 09-07-2015, 07:07 PM   #2
Yes, you are correct, there is a bolt underneath the bracket that goes across the the engine.
Support the motor with a piece of wood on a jack under the oil pan. Remove the 2 bolts (14mm?) from the top on the bracket reaching to the engine. Remove the 3 bolts holding the mount to the body. If you have a/c then remove the 10mm bolt that holds the a/c line down against the mount. Use a long extender a get underneath the car to remove it. With the head lamp you will see the bolt head. It I what makes the whole job a pita but once your new mount is in you'll enjoy t smoother idle.
Old 09-16-2015, 08:27 PM   #3
Kdaddy81
Did the rear cuz of the clunk in my wife's car tonight. What a pain. Got it done though and no more clunk or vibration between the two new mounts!!!
Old 09-19-2015, 06:34 PM   #4
Kdaddy81
Still kinda has vibration after the rear mount and the pass side one. Will doing the engine/tranny mount help? Can't hurt right?
Old 09-20-2015, 12:51 PM   #5
If the others needed doing and you're still noticing some vibration then yes definitely change all 3 of them. The trans mount is easy to do
BTW, how'd you find the rear mount attached to the subframe was to remove? The reason I ask is because on my Echo it is virtually impossible without removal of the subframe. It took me about 4-5 hrs to do because of how hard it was to install a bolt in a blind spot while trying to mve an engine to alllow it to match up.
