Drives: Yaris (06) Join Date: Nov 2015
After Market Horn - Hood Connectors?
Hi Everyone,
I wish to fit an aftermarket horn to my 2006 Yaris. I'm confident in electronics but want to check if there is an easily accessible connection in the hood / engine bay. I would rather install so that the stock horn can be re-connected at at will, so wire cutting / splicing I'd like to avoid. Does the stock horn have a wiring loom / connector block that is easily accessible? I just need a 12V+ to switch a relay, the rest I can wire myself. Many Thanks! |
There are a couple of threads on here with details on installing aftermarket horns. The horn itself has a very small feed wire, so ideally you do want to wire in a relay to feed the new horn. There is a Junction connector in the under-hood fuse box, which is the best place to grab the horn feed, to use it to feed the coil of a relay.
| My horn install... | Goose | DIY / Maintenance / Service | 7 | 01-29-2016 04:10 PM |
| C-One Replica Hood. Lets Fix this sucker! | TinyGiant | Cosmetic Modifications (Exterior/Interior) | 56 | 11-09-2009 11:31 PM |
| Micro Image Hood Design Contest | cali yaris | Micro Image | 209 | 10-04-2009 02:49 AM |
| Installed hood deflector, in-channel vent visors and hood seal. | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 16 | 12-20-2008 08:36 AM |
| Before you buy . . . check that hood! | woof | General Yaris / Vitz Discussion | 4 | 12-02-2006 05:14 PM |
