Old 12-09-2008, 05:11 PM   #1
IsLNdbOi
IsLNdbOi's Avatar
Installed hood deflector, in-channel vent visors and hood seal.
Finally installed my hood deflector and WeatherTech in-channel vent visors today.
The hood deflector I purchased from ToyotaPartsStore. It's the exact same one sold by Toyota in Canada and that Garm / cali yaris sells in his MicroImage Online store.
Here it is:
The deflector does protect most of the leading edge of the hood (a detail which usually can't be seen unless you're up close) and obviously protects a portion of the hood's surface.
Here are the WeatherTech in-channel vent visors:
I also did Kou's hood seal mod. I did it a little differently though. I ordered 4 feet of this:
http://soffseal.com/SearchByPart.asp
Part #: E006A
and just stuck it on. This weatherstrip comes pre-attached to double sided 3M weather-proof tape. 4 feet was a little long so I just cut it to the length I needed.
Old 12-10-2008, 12:40 AM   #2
Meteorite_Marty
Drives: 2008 5-door Yaris Hatchback
Looks awesome. Being in Canada, I have the same deflector installed as a dealer option when I bought the car. Functional and visually appealing.
I also have the in-channel window visors for my 5-door. These are Genuine Toyota visors, supplied as a dealer option. They have the Toyota logo in the same location as the Weathertech logo that yours has.
Stock photo.
Meteorite_Marty is offline   Reply With Quote
Old 12-10-2008, 12:46 AM   #3
keep us updated on the fitment of the visors from WeatherTech. Some have complained about them falling off
Old 12-10-2008, 03:21 AM   #4
IsLNdbOi
IsLNdbOi's Avatar
I have a feeling the same company makes WeatherTech's and Toyota's in-channel vent visors. Both have that little part at the front that go down for the front windows. When I had a 3-door LB, that part on both sides kept pulling out on their own. Ended up returning them. I believe another member here actually had his WeatherTechs fall out while driving on the highway.
With these new WeatherTechs for the 5-door LB, the two for the back doors both have double sided tape pre-applied. For the front doors, I put strips of 3M double sided weather proof tape on the part that goes downwards to keep them from pulling out on their own this time.
Old 12-10-2008, 09:11 AM   #5
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
I am curious on the extra hood seal....... will it do anything that will help? I would worry it would freeze the hood shut in the ice around here.
Old 12-12-2008, 05:12 PM   #6
mark schofield
Drives: 03 Echo, 04 Scion xA, 02 Range
I just bougt a 2009 3 door lift back. Has anyone purchased either an auto vent shade or weatherteck windo rain deflector kit by either of these vendors for the 2009 2 door model? TIA , Mark S
mark schofield is offline   Reply With Quote
Old 12-12-2008, 05:37 PM   #7
Chupacabra
Drives: 2009 Yaris liftback
Yep....I don't recommend it.
Chupacabra is offline   Reply With Quote
Old 12-13-2008, 12:12 AM   #8
kuyachris84
kuyachris84's Avatar
Drives: 2008 Yaris Liftback Black
Looks good. =)
2008 YARIS/VITZ LIFTBACK - BLACK SAND PEARL
Representing The Midwest!
http://www.cardomain.com/ride/3132598
kuyachris84 is offline   Reply With Quote
Old 12-13-2008, 02:55 AM   #9
IsLNdbOi
IsLNdbOi's Avatar
Are you really going to open your hood during winter when your car isn't inside your garage?
The WeatherTech and AutoVentShade in-channel vent visors for the '07 and '08 LB will fit the '09 3-door LB.
Old 12-13-2008, 09:53 AM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
of course im gonna open my hood even though its not garaged, its all part of keeping my engine clean when i give her a bath. NOW, can anyone confirm the freezing of the weatherstrip to the hood or is it just another negative comment as usual....
Old 12-13-2008, 03:17 PM   #11
Chupacabra
Agreed...I will open my hood as well!
Any seal will freeze when it's cold enough and there's residual moisture and/or moisture period. I don't recommend it for that reason
Old 12-13-2008, 03:29 PM   #12
IsLNdbOi
IsLNdbOi's Avatar
Why don't you try it? The weatherstrip is cheap. You obviously live somewhere where it cold enough for things outside to freeze.
Old 12-13-2008, 03:35 PM   #13
Chupacabra
I don't need to try it because I already know what will happen. When it's cold out...it will freeze.
Now... if you live somewhere where it doesn't freeze, this mod is just fine.
Old 12-19-2008, 11:32 PM   #14
auxmike
auxmike's Avatar
Got any pics of the hood open showing where the bug deflector mounts and how?
Old 12-20-2008, 08:52 AM   #15
ddongbap
I didn't know Siennas came in four lug.
Old 12-20-2008, 08:55 AM   #16
ROCKLAND TOYOTA
TRIM HUNTER
Old 12-20-2008, 09:36 AM   #17
auxmike
auxmike's Avatar
