Old 02-05-2016, 11:44 PM   #1
1nz revolution
Drives: 1nzfe
E85 Big Dog Pump
Walboro 460 E85 1NZ-FE Fuel Pump. Drop in and run wild.
1nz revolution is offline   Reply With Quote
Old 02-06-2016, 09:17 PM   #2
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
to run E85?.....all you need is larger injectors, E85 converter plug and ecu....dont need fuel pump
Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 02-07-2016, 11:04 AM   #3
1nz revolution
Drives: 1nzfe
That comment is almost hilarious. Yes you do need a better bigger pump, especially under boost. And spark plugs? That's the least of my worries. And to just drop in some larger injectors from another car is not the correct answer either. I've run E85 for 5 years and your where I was back then.
Old 02-08-2016, 08:31 PM   #4
rabbito
rabbito's Avatar
under boost, lol
Old 02-08-2016, 09:48 PM   #5
tmontague
tmontague's Avatar
So when do we see the set up run? I've so far only seen stills of your engine bay and parts...
Old 02-09-2016, 05:45 AM   #6
rabbito
rabbito's Avatar
you sound like one of them braggers boasting about their shit being the best from youtube..rofl..dude, we are just sharing information and ideas..chill out
Old 02-09-2016, 12:22 PM   #7
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Rabbito, your too new to know this but this IP user has been banned multiple times on this forum and other forums because of his attitude. Do a quick user search for xbgod. He has been working on this car since '10. Longest build with a huge budget ever.
-Derrick-
Old 02-09-2016, 01:18 PM   #8
bronsin
bronsin's Avatar
E85 needs to be euthanized. Using alcohol in gas raises food prices for the poor around the world and lowers our mpg.
It's a lose-lose proposition.
Old 02-09-2016, 01:35 PM   #9
rabbito
rabbito's Avatar
lol...okay
Water Pump, Do it myself or pay someone? cutchin DIY / Maintenance / Service 30 02-20-2016 12:09 PM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 11:41 AM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 01:33 PM
Water Pump issue, after taking in for Recall GeneralDon7 General Yaris / Vitz Discussion 34 05-27-2012 09:04 PM
So how do you like the BIG SMILE on the 07 Sedan???? Ziv General Yaris / Vitz Discussion 3 02-03-2006 12:12 PM
