#19 | |
2ZR swap. DO IT! Ask how!
The ECU tries really hard to get back to the factory fuel map, so the trims keep getting adjusted. If you have a nice snug belt on a Blitz S/C, you can actually get the MAF to go out of range and throw a CEL. I've also seen too lean, too rich, and misfires across all 4 cylinders, but it's gotten better since I isolated a lot of the vacuum leaks. |
#20 |
![]() ![]() ![]() Drives: 2007 Yaris HB 5spd Join Date: Jan 2015
Well I would think if the piggy back is doing its job efficiently it will keep the maf in check and I dont have a cel at this moment. Did when i was done with install but no codes now.
#21 |
The Blitz piggyback is really simple--it just forces the ECU into open loop when the magnetic clutch engages. The MAF signal doesn't get intercepted. Perhaps the piggyback for the Rotrex can be setup to clamp the MAF voltage, or just use MAP instead?
#22 |
![]() ![]() ![]() Drives: 09 Blizzard Pearl RS LB Join Date: Sep 2009
Hi OP,
Any updates on this Rotrex setup? Can you give any reviews on this product?
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| DIY: Colibri Power Window Install | Taiyaki | DIY / Maintenance / Service | 15 | 04-28-2016 10:03 PM |
| kit to install power locks? | songa | DIY / Maintenance / Service | 21 | 02-12-2015 07:31 AM |
| Installation of original power windows and locks in Yaris | lantis | DIY / Maintenance / Service | 4 | 02-25-2012 02:38 PM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
