Old 12-04-2008, 10:26 AM   #1
songa
Drives: 2009 Yaris Sedan (Black)
kit to install power locks?
hey guys, quick quetsion. i got a 2009 yaris sedan without the power package, so theres no power locks installed. however, i am interested in installing these eventually and did a search and found a kit on a1electric:
http://www.a1electric.com/Merchant2/...duct_Code=W02C
can anyone confirm that this is the right kit to use for my car? its a sedan so its 4 doors, and this kit is for the cable actuated locks, not the rod actuated ones. does this look like it will work? and any idea how much itd cost to have it installed somewhere? thanks!
songa is offline   Reply With Quote
Old 12-04-2008, 10:44 AM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
you can use that once since our car has cable controlled locks. if you do let me know how the install goes.
Old 12-04-2008, 11:19 PM   #3
b_hickman11
Drives: 08 Sedan
Thats the same exact kit that I installed on my 07 Sedan, except I bought the kit that came with a Keyless Entry unit. I installed it myself. It was very easy and it works great!
Old 12-04-2008, 11:31 PM   #4
auxmike
auxmike's Avatar
I sprang for the power package, worth every cent!
You get a power lock on the hatch too which is nice. Also, there's a feature that won't let the doors lock if you leave the key in the ignition.
It's all covered under factory warrenty too......
Old 12-05-2008, 02:42 AM   #5
Revsson
+1 for that
The a1 system looks pretty easy to install, too.
Old 12-05-2008, 11:15 AM   #6
Stargate YARlantIS
Stargate YARlantIS's Avatar
do they make one for the LB????
Visualize whirled peas.
Peace, Love and Good Smoke!
--Tommy Chong
Stargate YARlantIS is offline   Reply With Quote
Old 12-05-2008, 06:14 PM   #7
b_hickman11
Drives: 08 Sedan
yes, the same kit, just with 2 less motors.
Old 12-06-2008, 12:48 AM   #8
songa
yea, heres a few links to the right ones:
this one is just like the one i suggested but for 2 doors only:
http://www.a1electric.com/Merchant2/...duct_Code=W01C
this one is the same but with keyless entry:
http://www.a1electric.com/Merchant2/...ode=W01C-RF104
and this one has keyless entry and security alarm:
http://www.a1electric.com/Merchant2/...ode=W01C-B6000
peace!
Old 12-06-2008, 01:34 AM   #9
Revsson
peace!
They should include another relay/motor for the back hatch, too.
Glad I got the factory sysytem.
Old 12-06-2008, 10:19 AM   #10
auxmike
auxmike's Avatar
+1, true that!
The $1290 for the power package adds up to very little to your monthly payments when spread over a 60mo. loan.
I WOULD like to add keyless to my car though......
Old 12-06-2008, 10:51 AM   #11
b_hickman11
Drives: 08 Sedan
+1, true that!
It depends on what region you live in. The cost of the power package in my region is $1785 which is an extra $30 a month.
a1 also sells the part you need for the hatch. Here is the link:
http://www.a1electric.com/Merchant2/...Category_Code=
Old 12-06-2008, 04:46 PM   #12
auxmike
auxmike's Avatar
You have the sedan, I drive a 2dr hatch. Probably explains the price diff..
Old 12-06-2008, 07:34 PM   #13
b_hickman11
Drives: 08 Sedan
For the 2009 in my region there is only a $100 difference between the LB and Sedan power packages.
Old 12-10-2008, 11:36 AM   #14
Pitt Yaris
Drives: Flint Mica Sedan
i wanna install power locks....but where would you put the switch('s)?
Old 12-10-2008, 12:01 PM   #15
songa
hey pitt yaris, i believe you woul dhave to buy a new plastic molding for your door (im not sur ewhat its relaly called) that will have the bay open for your power lock switch. otherwise, you would have to home make something by cutting out a hole in your existing molding i guess. what i plan on doing is just having it so when you lock the door switch on the driver side door, all the locks lock together, and vice versa when you unlock.
Old 12-10-2008, 12:04 PM   #16
Pitt Yaris
i have a 2008.....it has the 2 vacant bays. was just looking at factory ones and saw theirs is on the door. i know the one under the left cup holder is for power mirrors.
Old 12-10-2008, 02:45 PM   #17
songa
ohh ok thanks. and yes i believe the power lock switches and also the power window switches are located on the door, so you would need to get a completely new part for your door that has those additional bays.
are the 2 vacant bays you are talking about, the ones right underneath the e-brake? i have 2 vacant bays there so im guessing you do too. do you know if one of those are typically used for a fog light switch? what could the other one be used for?
Old 12-10-2008, 08:50 PM   #18
b_hickman11
Drives: 08 Sedan
You don't need switches for the a1eletric kits. Your original door lock mechanism acts as the switch. I can lock or unlock all the doors by pushing the nob on the driver's door.
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 02:59 AM
Possible to only install the power mirrors? WolfWings DIY / Maintenance / Service 0 09-25-2007 11:04 PM
Question about Yaris power locks. OtownYaris General Yaris / Vitz Discussion 3 05-14-2007 09:48 PM
power locks and alarm install acrbill In Car Entertainment + Electronics (audio / video / alarm) 1 12-01-2006 12:17 AM
