![]() ![]() ![]() ![]() ![]() Drives: 2016 SE Join Date: Nov 2015
Low fuel warning and E ain't really Empty
wanted to see how much gas is really left at E
it took 9.6 gallons in the 11.1 tank from the manual ... Low fuel level warning light Indicates that remaining fuel is about 1.7 gal. (6.3 L, 1.4 Imp.gal.) or less. Refuel the vehicle. the warning light came on at 3 miles remaining so i have ~1.5 g left at indicated empty -- very close to the manual easily 50 miles good to know did you know the small "XP104" designation on the speedometer is spark plug type? ![]()
Yes good to know!
Also gtk the fuel pump is cooled by the gas in the tank and if you re running with no gas in the tank the fuel pump isn't being cooled!
#3 | |
gtk not running at all if there is no gas in the tank ![]()
![]() ![]() Drives: Toyota Yaris 2015 1.0VVT-i T2 Join Date: Jun 2012
Almost the same on mine...about 10 litres left in the tank.
Still gasoline for about 90-100km... The tank is 42L in the european. (If I remember correct)
Toyota Yaris 1.0VVT-i T2
| Low Fuel Warning Light | NYC-SE | Third Gen Yaris General Discussion | 18 | 08-18-2014 04:53 PM |
| Low fuel warning light not working? | Lerico | Third Gen Yaris General Discussion | 3 | 08-06-2014 05:27 AM |
| Bad Air/ Fuel mixture sensor warning for ALL Yaris owners | eric81 | General Yaris / Vitz Discussion | 31 | 04-21-2012 08:28 PM |
| General Warning and Fuel Tank Heat Shield | ttufrosty | General Yaris / Vitz Discussion | 8 | 05-31-2007 10:59 PM |
