![]() Drives: 2010 Yaris Join Date: Mar 2016
been driving my new to me 2010 yaris for a couple weeks, decided to double check engine bay, oil, etc.
noticed this hose just... floating there. Nothing obvious that it connects to, and i can't see what its supposed to be to. Anyone ? ![]()
That's the snorkel on the air intake box. It is not floating there. It is attached to the bottom of the black box you see beside it.
#3 | |
i guess im just used to it connecting to the grill or some obvious way to funnel air vs just wiggling there in space |
Yes
![]() Drives: 09 3dr HB 5sp Join Date: Apr 2011
Thats where you put the NAWZ
![]() ![]() Drives: 2013 Hatchback Join Date: Dec 2012
As other users pointed, is part of the cleaner assembly that provides the engine the necesary air for the combustion.The shape is designed to conduct air to the lower part of the cleaner, the air is forced thru the filter and large rubber hose connects to the intake manifold if i am not wrong.
![]() INLET, AIR CLEANER 17751-21160 |
right, on the subaru i traded in, the top part of this hose would have been connected to a portion of the front grille, to make sure air was being fed into the system.
It was just a little odd to see the top potion of the hose just floating free in space. Seems like having it face the grill would be better, but there is really very little need to have air forced into the system. Except maybe to make sure it was clean, cold air. |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
My air inlet resonator falls off while driving aggressively at 150kph and my yaris sounded like a sports car esp when i flat it out. I temporarily used 2 pcs of pvc elbow to make that u bend and it sounded like the stock air inlet resonator. I already ordered the original part 17751-0M070 and will be here in couple of days.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| HVAC dripping water when AC on. Drain hose is NOT clogged. | kustomrtr | DIY / Maintenance / Service | 3 | 09-07-2014 09:45 PM |
| DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
| vacuum hose / heater hose size | cali yaris | Performance Modifications | 12 | 05-17-2013 09:58 PM |
| Hose for windshield wiper broke | HDS | DIY / Maintenance / Service | 1 | 04-06-2012 10:26 AM |
